The Adcom GDA 600 modification thread
BTW-- the Adcom GDA for 100 bucks is still there,, local pickup,,,anybody?
McCloud Oklahoma craigslist.JC approves....he told me so. (F-1 nut) -
You interested in it George?
Ive never been to McCloud, but I could take a run out there for ya.
DaveOnce again we meet at last. -
thanks for the offer,,I was hoping someone here would jump on itJC approves....he told me so. (F-1 nut)
heheChassis mount,then just use some short lengths of hook up wire.
Okay-- for my education,please explain the wiring from the board to the chassis mount rca's,,I'll post a pic soon.I think I have it,just wanna be sure.JC approves....he told me so. (F-1 nut) -
george daniel wrote: »Okay-- for my education,please explain the wiring from the board to the chassis mount rca's,,I'll post a pic soon.I think I have it,just wanna be sure.
First I would make sure your chassis opening is big enough for the connector you plan on using.
After they are installed you would simply solder some short pieces of hookup wire from the new connectors to the same solder pads on the circuit board where the stock ones were removed from.(The center pin of the new con will be positive the outer solder tab will be ground).
Be sure to use the teflon insulating washers that come with the connectors as these isolate them from chassis ground preventing the posibility of creating a ground loop. -
I have a brand new in the box GCD-600 that has never even been opened that I saved for myself in case I ever wanted to downsize which I have been doing. I sold about 20 of these to guys I was setting up sleeper systems for where I wanted a big bang for the buck system. I always considered these to have a great sound.
I'll try the mod you are talking about as I am selling my beloved and revered Electrocompaniet EMC-1up.
These are so good I can only imagine what an improvement does.
Here's a little tip, find an Audience AU-24 or JPS Labs SC2 interconnect to use from the CD to your preamp and prepare to be blown away. They'll go for around $300 or so if you can find one.
Don't beat me up, I just saw that you were talking about the DAC not a CD player, oops. :eek:You aren't done with wire and ready for upgrades and other tweaks until you are totally done with wire.
Keith 2006 -
Or pick up some Neotech OCC I/C wire before it all disappears, that's what Audience uses."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'll have to check that out as I'm not a dealer anymore, thanks. I wasn't a fan of Audience the company, just the AU-24You aren't done with wire and ready for upgrades and other tweaks until you are totally done with wire.
Keith 2006 -
Don't beat me up, I just saw that you were talking about the DAC not a CD player, oops. :eek: -
I prefer MIT's, but thanks for the tip.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
This one?
http://www.vhaudio.com/neotech-nei-3002.htmlJC approves....he told me so. (F-1 nut) -
Yes, but I'd prefer to buy it from here: http://soniccraft.com/products/wire/interconnect/neotech.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
^^good question, maybe Fred will chime in.
Congrats, it should prove to be a very nice sounding unit.
Hi George,
I bought 12 ft of the neotech 3002 wire from soniccraft and am going with something else. PM me if you are interested. Good to see you are still doing the mods on this dac. Lots of help on teh forim makes it not so daunting of a task.Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server -
As I am doing this on a tight budget I started with Nationals lm6172 op amps in sockets this gave very good results.Now for a question does anyone know what resistors R502, R504, R540 & R541 and other channel R503, R505, R542 & R543 do?
To stop oscillation the power supply pins on the opamps are by passed with Rubycon ZA 100uF/25v in parallel with the original .1uF film and 1.5uf/25v tantalum (this is beneath the board) I picked this up from an application note on high speed op amps..... the Fets are not installed they are an option on my schematic.I will post some results when I get there.
George did you have any pics of the chassis mount RCAs you installed and did you end up going with the neotech? I am thinking about adding some extra set of RCAs to my amp with a selector switch while it torn down for repairs/mod.george daniel wrote: »Okay-- for my education,please explain the wiring from the board to the chassis mount rca's,,I'll post a pic soon.I think I have it,just wanna be sure.george daniel wrote: »
thanks, that helped me a lot!
regards,
chantal -
I've been playing with PC audio for the last 4 months, a learning experience which has shown me how insidiously destructive jitter is to lifelike musical reproduction. I have reached the point now where my PC is better than my my CD transports signal to the Adcom DAC.
Is there a reasonable project one could undertake to improve the clocking and reduce jitter for the GDA-600? -
thats on my short list of things to do,, hopefully this w/e--I'll update the thread with some pic'sJC approves....he told me so. (F-1 nut) -
Arrgh. Seems the Monster Cable M650i cables have quite a grip and the inexpensive RCA outer metal contacts on the GDA-600 crimped into place couldn't hold on. Looks like I'll be doing an unplanned upgrade using the RCA jacks from Musical concepts
http://www.musicaldesign.com/Connectors.html
Still wondering if there are any clock upgrades possible to improve the GDA-600... -
I did not know that it had a clock--shoot FGTV a pm if you want to know more regarding the circuit--what I tried to do was bang/buck tweaks.Mine is still doing fine,,sounding very analog and nice. Good Luck.JC approves....he told me so. (F-1 nut)
Did you do the analog upgrades yet? The clock is the last thing you should worry about.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You could concievably improve jitter performance by adding a second tighter PLL circuit .( such as that implemented in the UltraAnalog modified CS8412 used in the GDA700).Alternatively you could improve the clock in the transport.To take full advantage of such a mod one might also want to use true 75 ohm (BNC or RCA)input /output connectors and a good 75 ohm coaxial cable.
Another less cost effective option would be to add one of the sample rate convertor units from the likes of Monarchy or GW Labs.These are inserted between the transport and DAC.They reclock and resample the data mitigating much of the jitter from a high jitter source. -
There is no clock per se as the the digital input reciever chip(CS8412) recieves and locks to the master clock of the transport via a PLL circuit.
Exactly what I did,, got the Monarchy jitter reducer thingy between the Rotle 855 and the AdcomJC approves....he told me so. (F-1 nut) -
Hmm, so basically if I'm using a Linn Genki the clocking should be good and whatever I
hear has nothing to do with jitter? -
Worry about the analog section before the clock.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
hear has nothing to do with jitter?Worry about the analog section before the clock.
Ummm,he has. -
I have looked and I see nowhere indicating that he has done any mods to the analog section. I may have missed it though?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
