Another question about MIT IC Impedance
PolkClyde
PolkClyde Posts: 662
My Power amp has a Input Impedance of 115. is it okay to set the input Impedance to high,and Med for preamp.? or should they all be set at the same position? thanks,guys.
PolkAudioClyde
Post edited by PolkClyde on
  • ben62670
    ben62670 Posts: 15,969
    edited February 2011
    Try both. What sounds best to you is best.
    Ben
    F1nut Posts: 51,917
    No, if your amp is high and your pre amp is medium, that is what they should be set at.
