Another question about MIT IC Impedance
PolkClyde
PolkClyde Posts: 662
My Power amp has a Input Impedance of 115. is it okay to set the input Impedance to high,and Med for preamp.? or should they all be set at the same position? thanks,guys.
PolkAudioClyde
  • ben62670
    ben62670 Posts: 15,969
    edited February 2011
    Try both. What sounds best to you is best.
    Ben
    F1nut Posts: 52,406
    No, if your amp is high and your pre amp is medium, that is what they should be set at.
