Mission speakers.......
  • hamzahsh
    hamzahsh Posts: 439
    edited February 2002
    Russman goto www.dolby.com and check out all the pdfs especially the ones which says Dolby Digital vs. DTS.
    I can't post the huge articles here to mess up the forum.
    Thank You,
    Hamzah.
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • RuSsMaN
    RuSsMaN Posts: 17,985
    They are actually pretty small, and I didn't see them say anything about adjusting levels up or down on any channel.....
    Cheers,
    Russ
  • presidan
    presidan Posts: 116
    Nevertheless, i suspect that the article implie that the listening position was really centered, which isnt the case for lots of us, and they have symetric rooms etc....... It all matters in the end
    RT2000i
    F/X1000
    CS400i
    DENON AVR-3802
    PIONEER PDP 4360-HD 43"
