Tubes for Jolida
leroyjr1
leroyjr1 Posts: 8,785
edited June 2011 in Electronics
Need some good tube recommendations for the Jolida 100a cdp.
Post edited by leroyjr1 on
  • thsmith
    thsmith Posts: 6,082
    edited February 2011
    Sylvania 3 mice Black Plate 5751s
  • thsmith
    6moons recommends GE 5751 triple mica black plates. I do not have this player, yet but thinking hard about the sale that is going on.
  • dragon1952
    dragon1952 Posts: 4,907
    What are you playing it through and what speakers? Also, what tubes have you tried and what improvements would you be looking for?
  • Stew
    Stew Posts: 645
    TJ Full Music 12AX7's
    SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
    1000VA Dreadnought
    Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
    Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
    RTiA3, Onkyo TX-SR605
  • Jetmaker737
    Jetmaker737 Posts: 1,116
    Shuguang Psvane's
  • acmf74
    acmf74 Posts: 937
    edited March 2011
  • Dawgfish
    Dawgfish Posts: 2,554
    edited March 2011
    NOS 60's vintage RCA 12AX7
  • Dawgfish
    edited March 2011
    acmf74 wrote: »
    Yes, my recommendation is to stay away. Sovtek tubes came stock in my Anthem Pre1L preamp and come stock in many OEM tube components. There are many better sounding tubes out there, and some of them can be picked up at pretty reasonable prices depending on the tube type/size.
  • leroyjr1
    edited March 2011
    I've heard EI-gold pins pop up. Anyone know where to find a nice pair?
  • thsmith
    edited March 2011
    leroyjr1 wrote: »
    They are out there but rare and expensive.
    Maybe Jesse can confirm but I have heard the same version of the Ei without gold pins are just as good.
    I now have the JD100 and have tried Sylvania 3 mica BP D getter which is about $200 a pair and I have in the player now Treasure 12AX7s still burning in.
    While I still prefer the Syls the treasures sound great especially at half the price.
    I probably will put the Syls back in after the treasures are burned in and see which I like best. If margain is small I will sell the Syls.
  • Dawgfish
    edited March 2011
    leroyjr1 wrote: »
    While I did not try 12AX7s EI gold pins, I did try a set of EI gold pin 6922s and in my system to my ears they just sounded flat and tinny. I much preferred the NOS Mullard, Amperex, RCA, Phillips, and Sylvania tubes I tried. They all sounded much fuller and richer than the EIs to me.
    edited March 2011
    Not to steal the thread here guys. But what kind of 'life' do you get out of these various tubes. I noticed on the Jolida sites? One says 1000 hours warranty on tubes, the other 3 months. Surely tubes LAST longer than that--at least I hope they do because dishing out a few hundred dollars for tubes a couple of times a year is not going to cut it. I'm still mulling over the Jolida Music Van (the higher/newer model CDP) uses four tubes (in/out). I heard this model and was quite impressed with it. Although it must be added that it was paired with the best separates Jolida makes (the Music Envoy Monoblocks and associated tube pre along with a pair of fairly large Tannoy floorstanders). A really NICE sounding system!
    cnh
  • jhw59
    jhw59 Posts: 348
    edited March 2011
    I rolled these into my 100: 12AX7 Amperex matched pair -NOS (just under at 1500/1500gm 1500/1500gm) 1962 SEP. & OCT. large halo. Very nice sound
    I also bought (but haven't installed): NOS RCA BP 12AT7
    F1nut Posts: 51,766
    edited March 2011
    Both are true.
    Completely different tubes. The 12AX7's in the Jolida are anything but flat and tinny.
    F1nut Posts: 51,766
    edited March 2011
    In general, 9 pin signal tubes last a very, very long time. I've been running the same Ei set in my modded Jolida since 2006 and it's on most of the time. Those stock Jolida tubes are crap and it may be that they will not last long.
    Power tubes are an entirely different story.
    treitz3 Posts: 19,992
    edited March 2011
    I think I've had my Ei set in since '08 and it's on most of the time as well.
  • acmf74
    acmf74 Posts: 937
    edited March 2011
    I never pulled tubes out before. Do they just pop out or is there a tool/skill needed?
  • Timothy Smith
    Timothy Smith Posts: 764
    edited March 2011
    Hey Leroy,
    How does the Jolida sound with the stck tubes?
    Is it a big improvement over your Rotel 1072?
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • leroyjr1
    edited March 2011
    Hey Leroy,
    It hasn't arrived yet. I've heard from two polkies that's it a improvement over the 1072.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited March 2011
    leroyjr1 wrote: »
    Make that three,I also made the Rotel to Jolida move.
  • Timothy Smith
    edited March 2011
    leroyjr1 wrote: »
    WOW, you guys are already modding/tweaking while the new toy is still in transit by UPS!
  • Obsession18
    Obsession18 Posts: 191
    edited March 2011
    I put some Psvane 12AX7 grade A tubes in my Jolida JD-100 last Friday and left the player on continuos play all weekend to burn them in.
    Monday night it was time to see what they could do, what a difference - tighter better controlled bass, improved detail in the highs, and alot blacker background, worth every penny!
    If you own a Jolida - GET RID of the stock tubes!
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • starkiller
    starkiller Posts: 2,723
    edited March 2011
    I had some EI tubes in mine and it sounded pretty darn good:biggrin:
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • dragon1952
    edited March 2011
    Go with the Psvanes and get it over with.
  • acmf74
    acmf74 Posts: 937
    edited June 2011
    I recently installed a SC Magic PC with a pair of Shuguang Psvane's. I have about 24hrs of burn time on them and all I have to say is WOW.
