MIT IC's Impedance
PolkClyde
PolkClyde Posts: 662
I have the carver silver 7t Mono bloc and the impedance of the IC's set at med,is this right guys? I'm looking at the Silver 7t Manual now.it says, Input Impedance 115.Should I set the IC's to high? bare with me,I'm learning. thanks
PolkAudioClyde
Post edited by PolkClyde on
  • BlueFox
    BlueFox Posts: 15,250
    edited February 2011
    What does the MIT documentation say? For my S1.3 ICs they have 3 settings for different impedence ranges, but I forgot what they are.
  • PolkClyde
    BlueFox wrote: »
    Low: 5 >50
    Med: 40>100
    High:90 and UP
    PolkAudioClyde
  • dorokusai
    dorokusai Posts: 25,576
    PolkClyde wrote: »
    Set them at Med and forget about it, as it covers the most range of gear. The docs state it clearly but you'll have to make your own decision.
