How important is rca from HT pre to amp
polkfarmboy
Silly question to some I'm sure but have to ask
How important is the rca cables running from your pre to amp in a home theater deal?
I was connectiong my **o***a amp up to my pioneer receiver with monoprice rca cables and I think I should invest in better ones as I will be for sure buying a new amp and speakers shortly
What would you guys recommend for HT use ?
Are they less important and cheaper than a set of rca's you would use for connecting a cd player to a integrated tube amp?
Post edited by polkfarmboy on
I think the ***o**i*e cables you already have match up well with your *m***v* amp just fine.
FTR, I don't think you'll notice much difference in HT by upgrading cables anyway. At least I didn't. I only ended up upgrading the ICs for my front three, and that was mainly to improve the sound of my L and R for occasional 2-channel enjoyment. -
I noticed a difference. I also listen to 2 channel on my system and it was more of a difference there. From cheap rca's to Audioquest alpha snakes I could tell a difference. I then went from them to Signal Cable analog 2's and like them a lot better. I don't think i'm going to upgrade them any further as i'm very happy with the sound. I do think you'll notice an improvement, even in just HT.
mdaudioguy wrote: »I think the ***o**i*e cables you already have match up well with your *m***v* amp just fine.
I will be getting rid of the cables and the amp in that order so cables will be replaced first
Is there a certain length of cables I should go for ,distance is not an issue just wondering about the sonic characteristics of the length
I always see adds that catch my eye on audiogon offering MIT AVT2 10 foot rca from a seller named Joe Abrams' Equus Audio
Are the MIT's mention ed good for 2 ch and HT as they go for $123 a pair -
ideally, the length of your cables should only be as long as it takes to get connect the two in a neat fashion
