Kicker 100W Amp - $9.98
RuSsMaN
Fixed crossover, no gain control, and speaker level inputs only - but it's TEN DOLLARS on closeout.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=269-175&FTR=269-175
Cheers,
Russ
Cheers,
Russ
Post edited by RuSsMaN on
If i was to have an all Kicker setup i would buy this without a doubt simply for the cover as a decor piece. It's def worth $10
Get some leds under there so Kicker logo lights up and u're golden
Wonder if Polk will ever get a contract with auto manufacturers....2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
A stock radio and speakers and a sub with that amp, are made for each other.........literally
Not a bad looking piece of hardware.
$9.98? Heck, I think you can spend that much for a cuppa coffee at Starbucks... can't you? -
Picked 2 up yesterday for the he'll of it
Might throw one in the wifes car with a small sub
She has that built in stereo with the mpg
Computer so can't change the head unit. So this
Would work great. Question is do you tie it into the rear
Speakers? Run jumpers from them to the amp input? WonderingMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
The solid green wire connects to the left positive speaker wire (either front or rear).
The green/black wire connects to the left negative speaker wire (either front or rear).
The grey wire connects to the right positive speaker wire (either front or rear).
The grey/black wire connects to the right negative speaker wire (either front or rear).
I think I'm going to do the same thing, and find a 8" to stick under the passenger seat of her Vibe. It would be my first box build! -
Received my amps today, Cute little things.. the kicker cover fits right over the amp and could have led's installed somewhere to light up through the holes..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
a day late for me :0(
