Kicker 100W Amp - $9.98
RuSsMaN
RuSsMaN Posts: 17,985
edited March 2011 in Car Audio & Electronics
Fixed crossover, no gain control, and speaker level inputs only - but it's TEN DOLLARS on closeout.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=269-175&FTR=269-175
Cheers,
Russ
Post edited by RuSsMaN on
  • Vital
    Vital Posts: 747
    edited February 2011
    If i was to have an all Kicker setup i would buy this without a doubt simply for the cover as a decor piece. It's def worth $10
    Get some leds under there so Kicker logo lights up and u're golden :)
    Wonder if Polk will ever get a contract with auto manufacturers....
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • arun1963
    arun1963 Posts: 1,797
    A stock radio and speakers and a sub with that amp, are made for each other.........literally :smile:
  • Face
    Face Posts: 14,340
    mhardy6647 Posts: 35,377
    Face wrote: »
    Not a bad looking piece of hardware.
    $9.98? Heck, I think you can spend that much for a cuppa coffee at Starbucks... can't you?
  • faster100
    faster100 Posts: 6,124
    Picked 2 up yesterday for the he'll of it
    Might throw one in the wifes car with a small sub
    She has that built in stereo with the mpg
    Computer so can't change the head unit. So this
    Would work great. Question is do you tie it into the rear
    Speakers? Run jumpers from them to the amp input? Wondering
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • codyc1ark
    codyc1ark Posts: 2,539
    faster100 wrote: »
    The solid green wire connects to the left positive speaker wire (either front or rear).
    The green/black wire connects to the left negative speaker wire (either front or rear).
    The grey wire connects to the right positive speaker wire (either front or rear).
    The grey/black wire connects to the right negative speaker wire (either front or rear).
    I think I'm going to do the same thing, and find a 8" to stick under the passenger seat of her Vibe. It would be my first box build!
  • faster100
    Received my amps today, Cute little things.. the kicker cover fits right over the amp and could have led's installed somewhere to light up through the holes..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Flip8812
    Flip8812 Posts: 11
    edited March 2011
    a day late for me :0(
