New to me Amp...
jmwest1970
I picked up a Parasound HCD-1200 last week and am really enjoying the difference it makes with fullness at low listening levels. However, one thing I've noticed is that with the gain on the amp turned more than half way up I hear an annoying hiss from the speakers. Before I put the amp into the system I didn't hear this with my Cambridge Integrated. That integrated is now the preamp for the Parasound. I'm curious if those of you with Parasound exposure find the hiss normal, or is it more likely because I'm using the integrated amp as my pre?
Post edited by jmwest1970 on
I've got a 2250 and a 1000A with the gains turned to max and I get no hiss. Do you have anything else you can hook the amp to? An avr with preouts or something? Might be a good first check to see if it is the amp or the pre.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Probabally something to do with the pre,, do you have a cd with variable outputs,,if so,,hook it up directly to the amp and see,,,do you have CATV anywhere in the loop?JC approves....he told me so. (F-1 nut)
I've got the HCA 1200 mkii amp and have my gains turned to the max. I can hear a faint hiss if I get within a foot of my mains, It's easy to fixate on it,but really, when you move back to your listening area, you don't even notice it.
george daniel wrote: »Probabally something to do with the pre,, do you have a cd with variable outputs,,if so,,hook it up directly to the amp and see,,,do you have CATV anywhere in the loop?
There's CATV in the rack, but it's only hooked to the TV via HDMI. The only thing in common is the Panamax 5300. The Cambridge DVD has variable outputs. I'll give that a try. -
Polkie2009 wrote: »I've got the HCA 1200 mkii amp and have my gains turned to the max. I can hear a faint hiss if I get within a foot of my mains, It's easy to fixate on it,but really, when you move back to your listening area, you don't even notice it.
This is much worse. If I turn it up more the 3/4 gain I can hear the hiss at my listening position about 10' away. -
I don't like those pots in amps. You should be able to just install a jumper in place of the pot. This would allow full gain in the amp just like most other amps.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
jmwest1970 wrote: »This is much worse. If I turn it up more the 3/4 gain I can hear the hiss at my listening position about 10' away.
Tap the gain knobs and see if you get any noise... -
Both Parasounds that I've owned are dead quiet.
^Hiss and hum are two different things.
Could be time for Caig...More later,
Tour...
Vox Copuli
Oh my bad ...sorry. OP please ignore my post. -
As GD suggested I connected the stereo out on my Cambridge Audio DVD 89 directly to the amp and heard no hiss. It was as quiet as I can expect from mid-fi gear. It's definitely the 640a. I suppose this will hasten the search for a new pre. I need to win the lottery to get my hands on a Dodd Battery Preamp. I heard one of these at the Lone Star Audio Fest a couple of years ago setup by Russman and fell in love with it.
Cool...
george,
Why wouldn't the hiss have been heard from the Cambridge's amp section?More later,
Tour...
Vox Copuli
What do you guys think about a Jolida JD50A for a pre until I can find that miracle to buy the Dodd? I only have 4 sources, Blu-Ray, SACD, Squeezebox, and Xbox so I think it would hold me over.
