Looking for a time killer?
Jstas
Doesn't get much more fatal than this!
http://www.xgenstudios.com/castle/index.htm
Check the HELP link to figure out how to play.
Expert Moron Extraordinaire
Post edited by Ryan_Polk on
i got to level 14....couldnt hold off that big **** and all the small people...*sigh*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I got taken out at level 14 as well. And, of course, my games wouldn't save. I even set the space to unlimited, and it still wouldn't work. Anyway, check out this screenshot of the end of level _13_
Nice score, eh?
nadamsLudicrous gibs! -
Im up to 28!
300 Archers
100+ builders ---- 100+ wizards
Over 1,000,000 Spendable points...no idea on the total points, and still going...the archers and builders practically take care of theirsleves!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here ya go
-- Level 34.. - Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How do you get your wizards to be able to convert enemies instantly? If I just had that it would be so much easier. I just completed level 14, but I'm not ready to tackle 15 until my wrist gets a little rest.....Ludicrous gibs!
luckily I have a track ball...
Heres the down low
Level 5 - Buy the temple. Nuff said
CONVERT AS MUCH ENEMY AS YOU CAN!!!!
Fight off every bit of the enemy by throwing them until the end of level 13. Between that time you can buy the archer, builder, the lack(mana) w/e...
OK, now
at 14, start loading players in there. However, keep it slim on it because remember --- you have to PAY your units.
Level 14 is rather havoc, and so is 15, 16, etc --- but after 19 or so it calms down. I havnt used the mouse in over a hour.
How do you convert instantly?
you get atleast 16 wizzards, and hit 3 - click any stick people and boom.
Man...it cost me 152,000 for my units PER level. So basically, I earn about 200,000 and only get to keep 50,000 -- psssssssssssh
ah them stick muggers dont stand a chance! muahahahhaha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Read teh FAQ's and help pages about the game.
Things to do first.
Get a Temple and start converting guys. Second, get the archery range so you can train archers. Next, get the woodshop and train guys to constantly repair your castle. Next get the armory type deal (the dynamite) so you can start training suicide bombers.
That will put up a red flag on your castle. To train archers, click the red flag and you will see your archer count go up. Archers are needed to defeat the super huge stick guys.
To train repair guys, just convert enemies and click on the green flag. I found that 50-100 repair guys will maintain your power bar easily.
To train suicide bombers, click on the converted guys under your red power bar. The guy will run out of the castle with dynamite strapped to him. Click on him to detonate him.
To get wizards, which can also convert guys, you need a mana pool. You will need at least 20 wizards to have enough mana capacity to gain the convert guys spell. The FAQ and help files have info on the spells and how to cast them.
To convert guys, grab one of the enemies by clicking and dragging them into your castle and letting them go. Don't drag them too high or they will die when they kit teh ground. You will see a fat yellow beam shoot up when you are successfully converting a guy.
One thing to do is to buy as much fortification as you can. The more you have the longer it takes for the guys to tear your castle down. The longer it takes, the more time your archers have to kill them.
All guys cost spendable points per round to maintain. If you run out of points too quickly, your guys start dying and you lose them. So budget your points well.Expert Moron Extraordinaire
