Router buddy vs. jasper
VR3
VR3 Posts: 29,384
edited February 2011 in DIY, Mods & Tweaks
I wanted to comment that I bought the router buddy and have owned the Jasper jig before as well...
Hands down -- the Router buddy is built better - far more durable. I had rebuy a Jasper jig after the thin plastic they use cracked. The router buddy is waayyyyy more durable
Post edited by VR3 on
  • Face
    Face Posts: 14,340
    edited January 2011
    I'm on my second Jasper jig as well, but the first one did last a couple years.
  • 20hz
    20hz Posts: 636
    edited January 2011
    I always wanted one ended up building a new router base that has 5/16" coupler nuts welded on with that I can atach any length all thread rod to a center pivot , I found I can recess or cut anything over 8" .
    Anything smaller I make a template out of 1/8" masonite and use a 1/4" tracing bit I think its like the ones for formica .
  • Face
    Face Posts: 14,340
    edited January 2011
    Thanks for bringing this back up.
    I find it easier to get an exact cut with the Jasper, but the Router Buddy is built better, so pick your poison.
  • 20hz
    20hz Posts: 636
    how small a circle will those do ??
    I end up building a masonite drop in trace pattern for anything under 5" there has gotta be a better way ??
  • Jim Shearer
    Jim Shearer Posts: 369
    The Router Buddy will do small circles--I think I've gone as small as 2". Any less & it's just sensible to use a hole saw.
    As to getting an accurate size: I use a vernier caliper to set-up the RB. No problem getting the size right (at least as close as you can when cutting wood.)
    Cheers, Jim
    A day without music is like a day without food.
  • jinjuku
    jinjuku Posts: 1,523
    I have had a jasper jig for 5+ years now. Been trouble free and I have done quite a bit of work with it.
  • 20hz
    20hz Posts: 636
    (End quote)
    I use my router to flush the drivers to the surface than I use a hand held jigsaw to get the actuall hole in the wood .
    But it does sound like a router buddy is my next purchase :)
