Do I have this right???
muncybob
muncybob Posts: 3,267
Since both my avr and br player offer bass management it seems to me only 1 of them should actually do the job? In other words, one should be set to all speakers small to get bm having lfe sent to the sub and the other should be all large to not duplicate the effort?
I'm thinking my Oppo bd-93 may have better dac than my older Yammy rx-v1400 so do the mgt in the Oppo?
Yep, my name really is Bob.
Post edited by muncybob on
  • spock 2054
    spock 2054 Posts: 163
    edited January 2011
    I am assuming that you have the analog outputs of Oppo connected to the 5.1 analog inputs of your Yamaha. The best thing to do is experiment with the speaker settings in the Oppo, and your AVR and see what sounds better to you. See page 17 of your owners guide for your receiver. I think bass management only works from the Oppo to your receiver if you have an analog connection.
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • muncybob
    edited January 2011
    Yes, I'm running analog 5.1 only...using multi-channel on the avr for all music. Am I thinking about this correctly in saying if the avr is all speakers large that there is no bass management in the avr? Also, if I specify actual speaker distance in the Oppo I probably should then be sure all distances are equal in the avr?
    The more I think about this stuff the more I need an enhanced beverage!
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2011
    With analog only the distance and 80hz crossover setting in the Oppo apply. The speaker setup on your AVR only applies to digital sources. So you needn't worry about it.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • muncybob
    edited January 2011
    Great, thanks. Simplifies things...balanced system last night with a disc and analog sound meter...made my settings and played Yes "Fragile" DVD-A...sounded great! I think this weekend we'll watch Clapton's "Crossroads"...yum!
