Do I have this right???
muncybob
Since both my avr and br player offer bass management it seems to me only 1 of them should actually do the job? In other words, one should be set to all speakers small to get bm having lfe sent to the sub and the other should be all large to not duplicate the effort?
I'm thinking my Oppo bd-93 may have better dac than my older Yammy rx-v1400 so do the mgt in the Oppo?
Yep, my name really is Bob.
Post edited by muncybob on
I am assuming that you have the analog outputs of Oppo connected to the 5.1 analog inputs of your Yamaha. The best thing to do is experiment with the speaker settings in the Oppo, and your AVR and see what sounds better to you. See page 17 of your owners guide for your receiver. I think bass management only works from the Oppo to your receiver if you have an analog connection.polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
Yes, I'm running analog 5.1 only...using multi-channel on the avr for all music. Am I thinking about this correctly in saying if the avr is all speakers large that there is no bass management in the avr? Also, if I specify actual speaker distance in the Oppo I probably should then be sure all distances are equal in the avr?
The more I think about this stuff the more I need an enhanced beverage!Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
With analog only the distance and 80hz crossover setting in the Oppo apply. The speaker setup on your AVR only applies to digital sources. So you needn't worry about it.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Great, thanks. Simplifies things...balanced system last night with a disc and analog sound meter...made my settings and played Yes "Fragile" DVD-A...sounded great! I think this weekend we'll watch Clapton's "Crossroads"...yum!Yep, my name really is Bob.
