Posting video?
disneyjoe7
<object width="640" height="385"><param name="movie" value="http://www.youtube-nocookie.com/v/CrUjJhX5u7Q?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube-nocookie.com/v/CrUjJhX5u7Q?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
What I'm I doing wrong? HELP!!
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
On youtube, click the "Embed" button under the video you want to include. This gives you all you need to paste into the textbox. You also apparently need to do it from the "Go Advanced" rich text editor on this forum.
Yes but it didn't work for you either?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
It doesn't work in the "Forum Testing Area" forum for some reason, but in "The Clubhouse" it works fine. So does your code by the way. (Yours uses an object tag, where regular youtube uses an IFrame, but both seem to work.) When editing in the advanced mode, you can use the preview button to see if it will work or not before you submit the post. If you see the youtube window in the page it will work... if you see the HTML code, it won't.
I'm guessing vBulletin allows you to specify which forums allow HTML code to be pasted into the textboxes? Anyway, depending on where you wanted to post there might not be any way to get it to work because of options chosen by the moderators.
Ummm... I'm a little slow on the uptake. You can also scroll to the bottom of the page and look at the little box labeled Posting Rules. If it says HTML code is On, you can embed video. If Off, no go. -
"If it says HTML code is On, you can embed video. If Off, no go."
That's the problem Thanks.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
