Mediamonkey or Dbpoweramp?
13»
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited January 2011
    IIRC, you need to do Options>Media Netork and enable DLNA.
    Gotta have a port forwarded to that PC. then you can use WAN or LAN ip to access WebPlay, Webremote, etc.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Thanks I will do some digging in the options menu.
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2011
    I played around with it a bit, like somethings, didn't others. Initially comes across as really complex to setup. I saw on their site that you can watch netflix and hulu through it, but have not managed to get either one to work yet. :frown:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    Have you guys looked at WINamp Pro's portable media devices?
    Ben
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2011
    I am reviving this thread because I am sick of iTunes and Squeezebox not working together WELL for me. I have all MY music on a Netbook which does not have a cd drive. We have a borrowed usb cd drive right now which I have used to burn a few CD's into iTunes. I have an iTouch that I use a s a remote for the Squeeze Box Touch.
    I am not sure if I need iTunes. I would like to have a simple set up so I can listen to my music over the SBT and have the artwork show up properly.
    I am to much of a computer dummy to get help from all the big brains on the Squeeze Box forum. I am also cheap and would like to do this with a free program for the time being. I also do not want muck up my netbook with to much stuff. I have @ 32 gigs of music so it is not that much.
    I just want to keep it Simple.
    Any suggestions?
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • MillerLiteScott
    edited January 2011
    I downloaded Media Monkey. I am trying to figure it out. If I am recording using should I use flac and if I am what should the compression setting be?
    Scott
  • doctorcilantro
    edited January 2011
    Scott
    Are you ripping CDs? I think the default is level 6...that would be fine.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • audiobliss
    edited January 2011
    Since .flac is lossless there is no sonic difference with different compression rates. Only affect, afaik, is the strain on your processor to compress it more. However, I elected to use level 8 to conserve more space and since my quad core handles it just fine.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • doctorcilantro
    edited January 2011
    Yes, the only reason to consider different rates is storage space and decoding strain which used to be a concern on some handhelds that play .flac. Nowadays I guess most could handle even level 8 ?
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    edited January 2011
    You could try MC2Slim and try integrating the Squeezebox as a zone for J. River.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • MillerLiteScott
    edited January 2011
    I got the artwork to show up using MM for all of my MP4's but the few CD's I burned using MM in flac do not show up on my SBT.
    Any thoughts?
  • blakeh
    blakeh Posts: 491
    edited February 2011
    You have to perform a music rescan everytime you rip new music and want it to show up on the SBT. You can do it from the user interface (I believe it's on the first screen).
  • MillerLiteScott
    I did. The music shows up but will not play. I think their is a setting in the squeezebox server I need to change.
    Scott
    heiney9 Posts: 25,447
    Scott, for some reason, rarely, I have to unplug the SQB to reset it and then it works fine. I don't have to do this often, but every once in awhile that fixes it.
