7.1 or 5.1 w bi-amped fronts?
MFGlobal
MFGlobal Posts: 4
I have the Pioneer 1020-k
Monitor 70 fronts bi-amped
CS2 Center
rc85i inwalls surround
psw505 sub
Should I add 2 rc85i for rears and go 7.1 or stay bi-amped?
My first post...
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited January 2011
    I'd say you should listen to a mix of stuff bi-amped then go back to single wiring and listen again. I just did the same thing this morning with a Pio receiver and Monitor 70's and decided the bi-amping wasn't doing anything for me at all. The sound was actually smoother and better integrated when they were not bi-amped. If you're room is large enough to accommodate a 7.1 setup, I'd say you'll get more fun out of that.
    p.s. Welcome to the club!
    edited January 2011
    On3s&Z3r0s wrote: »
    So you did do it, cool, glad it worked out for ya.
  • MFGlobal
    MFGlobal Posts: 4
    edited January 2011
    Thanks for your input. I do get more sound from the 70s when they're bi-amped but it would seem that getting sound from different directions might create a better surroud experience. I'm completely new to this stuff. I have to say, I'm having a lot of fun with it!! Thanks again.
  • nguyendot
    nguyendot Posts: 3,596
    edited January 2011
    It's like a butt dyno... anything you think you got out of it is probably just what you're telling yourself is there, but isn't.
    Main Surround -
  • MFGlobal
    MFGlobal Posts: 4
    edited January 2011
    Seriously? Its all in my head?
  • On3s&Z3r0s
    edited January 2011
    MFGlobal wrote: »
    In my case, the improvement from going back to single wire was more apparent when listening to music... 2 channel sources. And, it didn't seem to make a big difference either way when listening to multi-channel material from a movie. Also, I have an SC-25, which Pioneer says is 140WPC, so I think the M70's just didn't need any more power than the amp could put out on the front channel by itself. There's a chance the difference would be bigger with your amp.
    As far as the 5.1 vs. 7.1 thing goes by itself, I think the real benefit to that is that with 7.1 speaker positioning you tend to place two of the surround speakers laterally with your seated position and then two farther behind you. I think this emphasizes the surround effect even on movies that aren't using a full 7 channels.
    I'd wait for some other folks to weigh in too before you go spending a bunch more coin... I'm definitely not an expert on any aspect of this. :smile:
  • MFGlobal
    MFGlobal Posts: 4
    edited January 2011
    Too late... Ha! Just ordered the rc85is on newegg for $149.99 with free ship. Newegg is the bomb.
  • rtart
    rtart Posts: 855
    edited January 2011
    Welcome MFGlobal!
    I'd say it depends mostly on your room size. Secondly, do you have a processor or AVR that will matrix 5.1 sources to 7.1? There isn't much 7.1 discretely encoded material out there. Some games, and a few movies on bluray are all I have found.
    I built my HT for 11.4 and use 7.2 right now. It's a big room, and I do matrix 7.1 on almost everything. It's a large room, and I have room for separation between the speakers.
    As I recall, Dolby labs website has a lot of info on speaker placement, even providing angles for speaker placement relative to seating position. I used their info years ago when designing my HT and have been very happy with the results.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • joeyf
    joeyf Posts: 15
    edited January 2011
    On3s&Z3r0s wrote: »
    I experienced the same thing... I have the same Pioneer VSX-1020k. My M70's sound sweet without the bi-amp. Right now I only have 5.1, but I'm kicking around getting 4 OWM3's to run 7.1.
