denon avr 3300 preamp quality
scottyboy76
i have been perusing the world of preamps, not terribly knowledgable about what makes one good, one ok, one lousy.
Generally speaking, receivers are not as good as separates, i get that.
How would the 3300s pre section rate, by the way marantz ma 500 u 125 watt amps would be used.
My goal is to have a 2 channell rig within my meager budget.
any help would be appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
While not 'ideal', older Denon AVRs are not bad as pre-amps for hybrid systems (2 channel and HT--I've used one myself and been pretty happy with it)!
If you have it. Set it up and take a listen; it will be an improvement over the Denon by itself!
Just not much exp. with other, quality separates to compare it to.
Someday, the dream is tube setup, its good to dream.humpty dumpty was pushed -
I have a set of those SDA's as well. The Denon will do you for now. Tubes, even better....though I don't have any myself. I have heard tube systems on SDAs and they're a bit otherworldly!
Enjoy!
