LFE Out vs Speaker Level?
groe
groe Posts: 2
Rookie question time. My old AVR had no LFE out so I had no choice but to use the speaker level inputs for sub hook up. My new AVR (Sony STR-DH510) has an LFE out so the question is do I use it? The Polk manual recommends speaker level inputs but a forum I read says this info is outdated now so use the LFE out. The system will be primarily used for home theater but also for music. Any recommendations would be welcomed.
Post edited by groe on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2011
    Use the LFE outputs, the bass management in the reciever should be much better than the sub, which usually won't even filter the lows from the main speakers.
  • dorourke07
    dorourke07 Posts: 298
    edited January 2011
    Does the AVR manual have a recommendation? I would go with the LFE output also. I'm not familiar with that AVR but you can probably make adjustments to the cross-over settings to get the best blend of sound from your fronts and the sub.
    Mains - LSi9's
    Center - LSiC
    Surround - pair of TL3's
    Amplification - Parasound 2125
    AVR - Onkyo 706
    CD/SACD - Onkyo DV-SP506
    SUB - MartinLogan Abyss
    55" Panasonic Viera TC-P55GT30 3D
    Bluray - DMP-BDT310 Panasonic
  • groe
    groe Posts: 2
    edited January 2011
    Thanks for the replies. No recommendation in the AVR manual per se but the sole speaker connection diagram shows only the sub out option so I guess that's a de facto recommendation. The AVR allows selection of x-over points from 40Hz-200Hz in 10Hz increments. Sub x-over is infinitely variable from 80Hz-160Hz. To avoid conflict do I simply set the sub x-over higher than the AVR x-over? Also the line inputs on the sub are L/R but AVR sub out is mono. Do I need a "Y" to spilt the mono cable or does L default to mono like most applications? No info in the sub manual on this.
  • cnoat
    cnoat Posts: 315
    edited January 2011
    You don't need a y adapter.Like you said it is mono.
    Turn your xover all the way up.
    Welcome to CP.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • dorourke07
    edited January 2011
    What he said. ^^^^^^^
    Mains - LSi9's
    Center - LSiC
    AVR - Onkyo 706
    tonyb Posts: 33,072
    edited January 2011
    groe wrote: »
    If your using the sub out connection on the AVR, and your speakers are connected to the AVR, then turn the crossover on the back of the sub all the way to the highest value. You use the crossover in the AVR's setup menu. You don't want to use both crossovers from the sub and the avr.
