Resistor question..
VR3
Well I am digging around in these Tyler monitors ---
Ty used a 15 watt 8 ohm resistor and a 25 watt 15 ohm resistor in the woofer network on these speakers...
Would you want to stay around the 20 watt mark or do I need to jump into the 50 watt range?
Thoughts...
Just so everyone knows - I already dropped the Hovland from my Super Towers in these lil monsters! HAHAHA - I am addicted to modding
Drop a few of these bad boys in there ?
Thoughts...
Post edited by VR3 on
Those 50 watt Mills are rated at 25 watts maximum without a heatsink, so they would be fine for what you want to use them for.Political Correctness'.........defined
President of Club Polk -
Excellent information!
I havent decided how far I want to dive into these monitors. The woofer, while nice, most likely would not benefit to heavily from a crossover upgrade...
The tweeter is very nice and the improvement was immediate going from a Solen to the Hovland. It amazes me still how a cheap cap can smear the high end of a speaker.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Excellent information!
I think you'd find that it will.The tweeter is very nice and the improvement was immediate going from a Solen to the Hovland. It amazes me still how a cheap cap can smear the high end of a speaker.
FYI, don't use the 50 watt Mills in a high frequency circuit.Political Correctness'.........defined
Most definitely, I am leaving the 10 watt non inductive eagle. I actually like that resistor alot even though it is only 1.50 -- the synergy in my super towers for whatever reason is off the charts...
Do you think just swapping out the resistors would yield a benefit? Or do you think doing all the parts would help?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Jesse have you broke down and picked up some Clarity MR??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Vr3MxStyler2k3 wrote: »Do you think just swapping out the resistors would yield a benefit? Or do you think doing all the parts would help?
It's like Chuck says, everything matters. Since you're deep into the modding madness, maybe try the resistors first, then the caps.Vr3MxStyler2k3 wrote:Jesse have you broke down and picked up some Clarity MR??
They don't come in the values I would need.Political Correctness'.........defined
All your fault Jesse - I ordered these just now for my lil monitors..
15.0 ohm Mundorf M-Resist Supreme Resistors
8.2 ohm Mundorf M-Resist Supreme Resistors
ClarityCap 12 mfd PX Range Polypropylene Caps
ClarityCap 22 mfd PX Range Polypropylene Caps
ClarityCap 3.9 mfd PX Range Polypropylene Caps
ClarityCap 8.2 mfd ESA Range Polypropylene Caps- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here is the original crossover with the Hovland thrown in there - kind of a crappy install since I was adding it in in 5.5" hole
Now that I look closer - very very similar...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Post# 2 reported!DARE TO SOAR:
Vr3MxStyler2k3 wrote: »All your fault Jesse - I ordered these just now for my lil monitors..
Always glad to help.
