Resistor question..
VR3
VR3 Posts: 29,538
edited January 2011 in DIY, Mods & Tweaks
Well I am digging around in these Tyler monitors ---
Ty used a 15 watt 8 ohm resistor and a 25 watt 15 ohm resistor in the woofer network on these speakers...
Would you want to stay around the 20 watt mark or do I need to jump into the 50 watt range?
Thoughts...
Just so everyone knows - I already dropped the Hovland from my Super Towers in these lil monsters! HAHAHA - I am addicted to modding
Drop a few of these bad boys in there ? ;)
Post edited by VR3 on
  • Kerinaria
    Kerinaria Posts: 1
    edited January 2011
    F1nut Posts: 51,954
    edited January 2011
    Those 50 watt Mills are rated at 25 watts maximum without a heatsink, so they would be fine for what you want to use them for.
    VR3 Posts: 29,538
    edited January 2011
    Excellent information!
    I havent decided how far I want to dive into these monitors. The woofer, while nice, most likely would not benefit to heavily from a crossover upgrade...
    The tweeter is very nice and the improvement was immediate going from a Solen to the Hovland. It amazes me still how a cheap cap can smear the high end of a speaker.
    F1nut Posts: 51,954
    edited January 2011
    I think you'd find that it will.
    FYI, don't use the 50 watt Mills in a high frequency circuit.
    VR3 Posts: 29,538
    edited January 2011
    Most definitely, I am leaving the 10 watt non inductive eagle. I actually like that resistor alot even though it is only 1.50 -- the synergy in my super towers for whatever reason is off the charts...
    Do you think just swapping out the resistors would yield a benefit? Or do you think doing all the parts would help?
    VR3 Posts: 29,538
    edited January 2011
    Jesse have you broke down and picked up some Clarity MR??
    F1nut Posts: 51,954
    edited January 2011
    It's like Chuck says, everything matters. Since you're deep into the modding madness, maybe try the resistors first, then the caps.
    They don't come in the values I would need.
    VR3 Posts: 29,538
    edited January 2011
    All your fault Jesse - I ordered these just now for my lil monitors..
    15.0 ohm Mundorf M-Resist Supreme Resistors
    8.2 ohm Mundorf M-Resist Supreme Resistors
    ClarityCap 12 mfd PX Range Polypropylene Caps
    ClarityCap 22 mfd PX Range Polypropylene Caps
    ClarityCap 3.9 mfd PX Range Polypropylene Caps
    ClarityCap 8.2 mfd ESA Range Polypropylene Caps
    VR3 Posts: 29,538
    edited January 2011
    Here is the original crossover with the Hovland thrown in there - kind of a crappy install since I was adding it in in 5.5" hole ;)
    VR3 Posts: 29,538
    edited January 2011
    Now that I look closer - very very similar...
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2011
    Post# 2 reported!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    F1nut Posts: 51,954
    edited January 2011
    Always glad to help. :smile:
