HK3490 + Monitor 40's
EndersShadow
EndersShadow Posts: 17,687
edited January 2011 in 2 Channel Audio
So right now I got Infinity Primus 162's hooked up to my HK3490. I am debating seeing how the Monitor 40's do on it. Then whatever speaker I like better stays. Personally leaning toward the 40's since it gives me some extra space downstairs on the mounts to position things better.
My question is can I connect A & B on the HK to the a different set of binding posts on the Monitor 40's. I know this isnt bi-amping in its true form.....but would it work???
Post edited by EndersShadow on
    tonyb Posts: 33,065
    edited January 2011
    Sure it would work, don't know why you would want to though. Two squirrels in a cage can drive those M40's with ease.
    edited January 2011
    tonyb wrote: »
    Just to try it out...see how it sounds. Its one thing to read about it from those that have done it, another to have done it and heard yourself.
    Who knows maybe it will knock my socks off, maybe it wont. I just didnt want to do it if there was any chance it would blow the HK. Its WAAAAYYYYY to nice for that.
    Plan this weekend is to have silvertuner over to let me listen to my Infinity Studio Monitors he got from me and modded, and AB those against my Primus, maybe the 40's.
    Possibly gonna use the HK to drive my T90e's and then drive some of that stuff from the my Carver AV-705x amp.....
    Also possibly some vintage low wattage recievers the mix to give even more comparisons....
  • silvertuner
    silvertuner Posts: 496
    edited January 2011
    think that carver could drive those sansui speakers? lol. i dont have anything that can drive them and give them any REAL power until i get the amp hooked up and see if even fires up without burning my house down lol.
    im looking forward to this. then sunday i get to mod my step-dads ss-mf515's. ugh, i hate all of you for making love good audio
    btw, that hk3490 as a pre for the carver, i think may leave a little to be desired, but we may find out huh
    some cheap free sony speakers
    psw125
    denon 1610
    3.1 channel because i hate cables ran across the living room like that
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    You are better off just hooking them up normally. The way you propose would require an extra set of cables. You would be much better off with one set of good cables than two sets of mediocre cables. Also you would be using the same power and output devices "BiAmping" them.
    Ben
