Up against a wall
polkfan38
polkfan38 Posts: 360
edited January 2011 in Speakers
OK. So I have Monitor 50s picked out for the fronts. I am going to go 7.1. I want to go with Monitor 30s for the surrounds and rears. My only problem is that I have to put them up against the wall with maybe a inch gap between the back of the speaker and the wall. Is this going to hurt the performance much as they are just surrounds and rears? I know I have played around with Monitor 40s and, for the mains, they seem to like almost a foot space from the wall. If it is a big deal, I will have to go with something front ported. Like the RTi line. Which brings my budget up considerably.
Thanks!
Things are more like they are now than they ever will be!
Post edited by polkfan38 on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    That will be fine. You are going to cross the rears over at 80-100hz anyway. The port doesn't really come into play that much there.
    Ben
    Ben
  • polkfan38
    edited January 2011
    I didn't think so but, I wanted to be sure. And like I said, there will be a little gap there.
    EndersShadow Posts: 17,722
    edited January 2011
    Yeah I have my Monitor 40's like 2 inches from the back wall and notice no difference at all...
  • polkfan38
    edited January 2011
    Thanks 'Shadow! I am going to use my Monitor 40s as a template for positioning. If those work out, I might just get another pair of 40s to complete the set. Size is my main concern now.
