Speaker placement????
Geoff4rfc
Geoff4rfc Posts: 2,805
edited January 2011 in Speakers
Posted on AVS,
I've got 70 seriesII, CS2 and 30's currently in surround. I'll be adding 40's.
Question; leave 30's in surround and place 40's in wide position? Or move 30's to wide and place 40's in surround?
My thought is the surrounds get more activity than the wides so using the 40's there would be more efficient.
Thoughts and opinions?
Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
Post edited by Geoff4rfc on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited January 2011
    Geoff
    I'd grab some banana plugs from monoprice and make it easy to try it out both ways. I'd search AVS or here under movies and try to find specific titles that are know to take advantage of wide position. I have the option for front height or rear surround w/ my Denon but haven't hooked up any extra speakers to try it. With the plugs and good source material it should be easy enough to try both options, but you will probably have to rerun setup for the avr in each scenerio.
  • Geoff4rfc
    edited January 2011
    TNHNDYMAN wrote: »
    Geoff
    Thanks handy man from TN. My Onk 807 lets me choose from height, wide or rear surrounds. I haven't tried the rears but I've tested from the height vs wide and found I get more activity from wides.
    I don't expect a lot from the rears but I get quite a bit from the surrounds. In fact, I have my surrounds positioned in the rear and have been getting great results with that.
    I reckon you right though, nothing like good 'ol trial and error :smile:
  • Geoff4rfc
    edited January 2011
    Geoff4rfc wrote: »
    Posted on AVS,
    So........nobody else has any experience with these possible set ups they'd like to share?
  • polkfan38
    polkfan38 Posts: 360
    edited January 2011
    We need to get on the same page with terminology. The speakers to your side are the surrounds. These will get more "info" than any of the others. Use the 40s here. The rears are the ones directly behind you. These don't get much "info". Use the 30s here. As for "wides" and "heights", Use Monitor 30s for these. These are just processed channels from the AVR.
    Things are more like they are now than they ever will be!
  • Geoff4rfc
    edited January 2011
    polkfan38 wrote: »
    We need to get on the same page with terminology. The speakers to your side are the surrounds. These will get more "info" than any of the others. Use the 40s here..
    Thank you, this is exactly where I said my 30's were and was asking if the 40's would be a better choice.
    polkfan38 wrote: »
    Thank you again, this answered the second part of my question.
  • polkfan38
    edited January 2011
    If the room is big and/or you have the room and like things loud, the Monitor 40s would be good in the rear too.
