Nad T975 amp for RTI's?
turbojohngt
turbojohngt Posts: 16
edited January 2011 in Speakers
I'm currently running my rti 10 rti4 and csi3 with a onkyo 876. Would it be worth upgrading to a NAD T975? And would it be to much power for my rti 4's? Thanx In advance guys.
Cheers, John
Post edited by turbojohngt on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited January 2011
    Seems like an excellent choice to me! :smile:
    If you're concerned because it exceeds the recommended amplification of the RTi4s, don't be. You'll not be cranking that much power to surrounds.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2011
    The NAD would be a good choice.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • turbojohngt
    edited January 2011
    Will I notice any significant difference sound wise going with the NAD (Onkyo 876 as a pre amp) as both put out 140 watts per channel? My rig is mainly used for movies, no 2 channel music.
  • mdaudioguy
    edited January 2011
    It depends on how discerning of an ear you have. I watched Inception last night at a pretty good volume, and I'm not sure if the AVRs I've had could "bring it" on their own like my current setup with an amp does. That said, I'm hard-pressed to discern the subtle nuances in movie soundtracks that I can notice in music.
  • mantis
    mantis Posts: 17,378
    edited January 2011
    Onkyo makes nice receivers but not on the level of the NAD especially for sound quality and dynamic range. You will notice a increase in overall clarity of your system bringing out the very best your speakers can be.
    Their are watts and then NAD watts which are real power. NAD maybe ugly to look at but they perform better then most.
    I'm afraid that using your Onkyo as a pre will only hinder the performance of the NAD amp. I suggest replacing it with this instead of your current thinking of upgrading. This is a much better overall choice for your system.
    http://nadelectronics.com/products/av-receivers/T-775-A/V-Surround-Sound-Receiver
    Dan
