B&K Reference 30 pre/pro
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2011 in For Sale (FS) Classifieds
This is one of the best sounding pieces of electronics I have heard. It has digital inputs as well as DVD-Audio inputs for multi-channel sources such as Blu-Ray for playing decoded Dolby THD and DTS MA. The sound is incredibly clear without any mechanical harshness, and with solid but not mushy bass.
I bought this from fishbones about 4-5 months ago. I no longer need it as I also got a Ref 20 and a Rotel and Denon receiver around the same time.
The unit is in exceptional condition. I could find only two pinhead nicks that are not visible from a foot away (at least to me).
All outputs and inputs, channels and digital formats were checked out last week and worked as they should.
$380 shipped to CONUS only. Also listed on Agon for $425 shipped. Two remotes and heavy duty power cord. Retailed around $2800.
Full refund if DOA and shipped back at my expense within 7 days; any other issues, you can return within 7 days for full refund but shipped at your expense.
Paypal preferred. Add 3% if there will be PP fees.
This is a tremendous value for great equipment.
Post edited by NeilGabriel on
  • NeilGabriel
    edited January 2011
    While watching the Eagles take a hit, I remembered that when I had the pre/pro hooked up with a Rotel RB-985, I thought that the right rear channel played at a lower volume than the rest. Fishbones (Troy?) told me he had never had a problem. I then switched some components and it seemed to be fine. So, I am not sure if there is a problem there or not. But, it ran fine after the switch. Because I then went to a receiver in the HT, I have used the B&K in my 2 channel system. At its price, it makes a great 2 channel pre as well.
  • fishbones
    fishbones Posts: 947
    edited January 2011
    2-channel music is done very well by this unit. (I would know :biggrin:). Surround sound I didn't take to nearly it's potential (always had crappy dvd source). For music, it nearly kept up with a Cary Tube Pre - not an easy feat...Tubes won out only in smoothness, but everything else was right on. And like Michael said, I had no issues with it. GLWTS!
  • mantis
    mantis Posts: 17,557
    edited January 2011
    While I owned the B&K avr307 (which had a ref 30 built in) it'ss very musical and one of the finest preamps money can buy under 3000.00 of that era. Theater is done very well with this pre and it has room correction in it's notch filters. Bass is where things tend to need the most correction hence why B&K choose to do correction here. Very advanced for it's time.
    Good luck with the sale , this should make someone very happy if looking for a high quality preamp and doesn't need video switching over HDMI.
    Dan
  • EDUBAG
    EDUBAG Posts: 403
    edited January 2011
    would this go well with a rotel rb 990bx? i am looking for a pre for that amp to ise as a two channel system with my rtia7
    please advise,
    regards,
    eduardo
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • NeilGabriel
    edited January 2011
    In my opinion, this functions as a great 2 channel preamp. I had been using it with a Rotel RB-985 before I decided it didn't make sense to use a multi-channel system for 2 channel. I bought the Rotel 1050 receiver to replace them. It sounded great in my system with LSi9's.
    fishbones also commented above about his use of this very unit in a 2 channel system.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2011
    That looks like it might be the most versatile pre I've eve seen! Dang, there are about 100 different places to plug things into the back of it. At your amazing $380 price that's under $4.00 per connection! Good luck with the sale.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • NeilGabriel
    edited January 2011
    I am going to take the big hit on this so I can get some additional money for Rotel receiver repairs.
    $360 shipped to CONUS.
    I also have the B&K Ref 20, does not have the multi-channel inputs; otherwise, very much the same as the Ref 30. I don't use either because I bought HT receivers (so kick me off the forum!).
    The Ref 20 is $325 shipped to CONUS.
  • shawn474
    shawn474 Posts: 3,052
    edited January 2011
    If you ever decide that you're up for a trade I would give you my psb 5.0 speaker set for the reference 30. Just a thought.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • danz1906
    danz1906 Posts: 5,144
    edited January 2011
    Great pre- If I remember correctly you can set-up all kinds of pre-sets.
    Good luck with the Sale!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • NeilGabriel
    edited January 2011
    shawn: what would they cost to ship do you think...?....do you know how they compare to some other Polk speakers...like a Monitor 5, 4?
    I don't really need more speakers....but I do need MONEY! I see a lot of the Polk surround speakers on Craigslist.
  • shawn474
    edited January 2011
    Mike,
    Not sure what they would cost to ship, but I would definitely help out with that. The only polk speakers I have really tried out in my system are the older RT series and the TSi series. They obviously don't have the bass response that the Polk models do due to sheer size, but the midrange and tweeters perform very admirably for HT and musicality. They are a maple color and are easily mounted. All in all, I think you'd be hard pressed to find a better setup for the price (and we could do an even trade if we can figure out how to split the shipping costs) if you're interested.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • NeilGabriel
    edited January 2011
    Sale pending on Audiogon.
    How about that Ref 20....still a charmer!
  • raffi
    raffi Posts: 114
    edited January 2011
    Dang NG, I'm glad this is selling on AG....it was gnawing at me mind. ;)
    2 channel rig: MMF 2.2 turntable, Adcom GFP-715, Adcom GFA-555, Adcom ACE-515, Carver M-1.0t, Denon 5900 CD/SACD, SDA-SRS 2.3s (Zardoss modded), AQ Diamondback & King Cobra IC's and AQ Type 4 speaker cables
    HT rig: Panny 50" G20 plasma, Directv DVR, Insignia BRD/DVD/SACD/DVD-A, Denon AVR-890, Fronts: Polk Monitor 70's, Rears: Deftech Mythos Gems, Center: Polk CS1, Sub: Polk PSW-505
  • NeilGabriel
    edited January 2011
    the Ref 20 is even a better deal! cables are a week old and ran about $45.
  • raffi
    raffi Posts: 114
    edited January 2011
    I know I know, but I need a turntable 1st...damnit! And since I'd only be using it for 2 channel, I'm guessing it wouldn't be any less of a performer than the 30. Argghhh...somebody please buy this.:rolleyes:
  • NeilGabriel
    edited January 2011
    The old Ref 20 was the heart of my 2 channel for about a year...until lightning got her...used it with both a NAD C262 2 channel amp and a Rotel 5 channel where I biamped the LSi9's...it sounds good using digital or analog inputs...I can see you drooling....
  • Systems
    Systems Posts: 14,872
    edited January 2011
    I have to agree 100%.
    You can't go wrong, I have the 20 & 30 and would not sell them because they offer performance way out of their price range.
    You would have to spend waaaay more $ to get better performance IMHO!:wink:
    Testing
    Testing
    Testing
  • PSOVLSK
    PSOVLSK Posts: 5,398
    edited January 2011
    How would you compare the Rotel 1050 to the Ref 20?
  • DON73
    DON73 Posts: 516
    edited January 2011
    If the AUDIGON sale doesn't go through PM me.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • DON73
    DON73 Posts: 516
    edited January 2011
    Found one! Disregard request for PM.
