Would the Rti4 be a good addition as Front High speakers in my 7.1 setup?
stangjason
I'm considering a small and cheaper addition to my HT setup or I might use them for some side or rear surrounds if I can find a place for them.
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
Post edited by stangjason on
Rti 4's would be a perfect addition to your current setup, but I don't think your receiver will do 9.1.
Oh no I meant I would do a 7.1 but I'd do 4 front speakers plus centerPioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
4 front speakers? Are you planning on running the rti 4's off the front speakers?
Unless you put your front hight speakers very high,you will not get a effect that you think you will..I have front hightz up and, my ceiling is to short for the hightz to do any great affectsSamsung PN50B550 Plasma
Pioneer Elite SC-25
Pioneer Elite BDP-23FD
Adcom 7500 Amp-Panamax 4300 Conditioner
Polk RTi10's Fronts
Polk Csi A6 Center-Polk M60s rear Surrounds
Klipsch Synergy Sub-10 X2
Klipsch Synergy S-10 Premium back surround -
I see this may not work for me because we have a standard ceiling and I'm pretty sure I won't get wife approval to place them higher than the towers next to our TV anyways.Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
just use 4 rear speakers. i think it will make the biggest difference.50" samsung dlp
receiver... pioneer elite vsx72txv
front... polk tsi400's
rear surrounds... polk tsi100's
center... polk csi3
subs... psw150..... 2 of them.
surrounds.....polk owm3's -
Is it worth getting two more speakers with this receiver considering it's got a rather weak amp section? I believe it's 110 watt rating is way overrated though I'm pleased with its output in 5.1.Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
Why mess with it if you're pleased? 5.1 is great. You need a fairly large room to really appreciate 7.1.
I've done a front wide and front high setup and it's cool, but for a small room....let's pick <20 wide, I wouldn't spend the money. My experiment was with dual SurroundBars so YMMV.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
mdaudioguy wrote: »Why mess with it if you're pleased? 5.1 is great. You need a fairly large room to really appreciate 7.1.
My room is fairly large I think but my listening area isn't if that' makes sense. My HT room is my living room which is an open floor plan so my left channels have no wall while my right channels have a wall with an opening into our bed room (mini hallway and a 45 degree turn into a bedroom w/door). The right rear surround speaker has a wall behind it while the left rear has an open area where the front door is located...confused yet :biggrin: I may have to post picks but excuse the mess because we have a 3 month old and a 2 year old that strows everything around the house she can get ahold of .Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
i added rear surround to my setup, and i can actually notice the difference. i'm currently using an 80wpc yamaha, and it's good. i will be getting the 1120 though, so i think it will get a little better. i think that the rear surrounds don't require tons of power, so the receiver you have should be just fine.50" samsung dlp
center... polk csi3
