Why one THX Ultra and the other Select- SAME AMPS
larry777
Why is the Pioneer SC-37 rated THX Ultra and the SC-35 rated THX Select ? They both use the same class D Ice Amps at 140 Watts per channel. So shouldn't they put out equal power ?
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Post edited by larry777 on
The THX rating involves a lot more than the AVR's power rating. I'm not even sure if the power rating is even a factor in an AVR's THX designation.
It has more to do with the AVR's processing and auto calibration abilities.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Google it. As Curt responded, it's more about processing and features. There are different levels, none of which matter to me, because I'm satisfied without THX "certification".
P.S. The THX intros before the movie are pretty cool, though!!
mdaudioguy wrote: »Google it. As Curt responded, it's more about processing and features. There are different levels, none of which matter to me, because I'm satisfied without THX "certification".
+1 on the movie intro and who cares if your system is THX certified!Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
THX doesn't mean anything that you should lose sleep over but it's a cool logo.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Reminds me of the simpson's episode in the theater.
Link: http://www.youtube.com/watch?v=K3_HHZFi0As -
It's mainly can it attain a certain quality, and sound level (105db reference) in a certain space (cubic feet, generally 2000 for Select, 4000+ for Ultra)
Maybe they just didn't want to pay for the Ultra cert on the 35. It makes the 37 look more appealing because of the badge.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
As stated above, as far as amps go in AVRs, the U2 rating allows reference level in a larger space, also, IIRC there is something going on with the 4 ohm operation (could be wrong on that).
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Thats great...thanks for the comments. It seems like this THX Certification is nothing to be concerned about and that the SC-35 will be fine with the THX Select Plus.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Van Den Hul Interconnects -
Just don't come crying back to us when you're sitting in the middle of your 4000 sq ft living room and things aren't whirring like they should.
Actually, come to think of it.... if you've got a 4000 sq. ft. living room, just don't talk to me at all.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Cubic feet.
My living room (#2) is 25x25 x 8 ft... for 4000 cu ft.Main Surround -
:redface: - that makes a slight difference65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Yes,I did understand that cu ft comes into play with a decision to go Ultra or Select. My room is aprox 2600 sq feet. And my longer term plan was to add a power amp to power at least the front 3. based on this extra info, I should be ok with the SC-35 and THX Select then ?Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
If I remember correctly THX select will deal with a room smaller than yours and Ultra is geared toward a 3000 cubic foot space. So probably Ultra in your case. You can probably google this, as suggested above.
I often sit in front of my Onkyo staring at the THX ULTRA logo and chanting AUM!
Nothing has happened....yet?
cnh
Select/2 is for 2000 cubic feet and smaller. Ultra/2 is for 4000 cubic feet and smaller.
Your room is 2600 sq ft? What is it a warehouse? For one that large you're looking at a real Bona Fide THX (as in have lucasfilm come down and certify your room) certification.
At that level you'd need THX speakers, cables, receiver, amps, etc to reach the 105db required by the standard.Main Surround -
I'm pretty sure the OP means 2600 cu. ft. because, as you say 2600 sq. feet is over 50' x 50'...one hell of a ROOM!
Which THX Certification Is Right For You?
THX Ultra2
THX Ultra2 Certified products bring the cinematic experience to larger home theaters, 3,000 cubic feet in size, with a viewing distance of 12 feet or greater from the screen.
THX Select2
THX Select2 Certified products are for medium sized rooms, up to 2,000 cubic feet in size, with a 10-12 foot viewing distance from the screen.
THX I/S Plus Systems
Certified Systems (AV Receiver + Speaker Bundle) have the power to fill a small home theater or dorm room where the viewing distance from the screen is 6-8 feet.
THX Certified Multimedia Products
THX Certified Multimedia Products are designed and engineered for PC gaming and multimedia on the desktop.
Sorry guys that should have read CU Feet and not SQ Feet. I remeasured, and the room is 2400 Sq Ft and not 2600. After considering other family members, the maximum volume will be about -15 and possibly down to -10 and in most cases above -15. thats why I was thinking the THX Select option of the SC-35 would be suitable for my room size. And as pointed out I will likely add an AMP for at least the front 3 later on if that matters. I also understand when playing below Reference Level that the THX Loudness Plus option will give you the same sound as recorded on the original soundtrack,but at a lower volume.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
