Why one THX Ultra and the other Select- SAME AMPS
larry777
larry777 Posts: 480
edited January 2011 in Electronics
Why is the Pioneer SC-37 rated THX Ultra and the SC-35 rated THX Select ? They both use the same class D Ice Amps at 140 Watts per channel. So shouldn't they put out equal power ?
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Post edited by larry777 on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    The THX rating involves a lot more than the AVR's power rating. I'm not even sure if the power rating is even a factor in an AVR's THX designation.
    It has more to do with the AVR's processing and auto calibration abilities.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited January 2011
    Google it. As Curt responded, it's more about processing and features. There are different levels, none of which matter to me, because I'm satisfied without THX "certification".
    P.S. The THX intros before the movie are pretty cool, though!! :smile:
  • thuffman03
    thuffman03 Posts: 1,325
    edited January 2011
    mdaudioguy wrote: »
    +1 on the movie intro and who cares if your system is THX certified!
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    THX doesn't mean anything that you should lose sleep over but it's a cool logo.
  • grimmace19
    grimmace19 Posts: 1,429
    edited January 2011
    Reminds me of the simpson's episode in the theater.
    Link: http://www.youtube.com/watch?v=K3_HHZFi0As
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    It's mainly can it attain a certain quality, and sound level (105db reference) in a certain space (cubic feet, generally 2000 for Select, 4000+ for Ultra)
    Maybe they just didn't want to pay for the Ultra cert on the 35. It makes the 37 look more appealing because of the badge.
    Main Surround -
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2011
    As stated above, as far as amps go in AVRs, the U2 rating allows reference level in a larger space, also, IIRC there is something going on with the 4 ohm operation (could be wrong on that).
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • larry777
    larry777 Posts: 480
    edited January 2011
    Thats great...thanks for the comments. It seems like this THX Certification is nothing to be concerned about and that the SC-35 will be fine with the THX Select Plus.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2011
    Just don't come crying back to us when you're sitting in the middle of your 4000 sq ft living room and things aren't whirring like they should.
    Actually, come to think of it.... if you've got a 4000 sq. ft. living room, just don't talk to me at all.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • nguyendot
    edited January 2011
    Glowrdr wrote: »
    Cubic feet.
    My living room (#2) is 25x25 x 8 ft... for 4000 cu ft.
    Main Surround -
  • Glowrdr
    edited January 2011
    :redface: - that makes a slight difference
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • larry777
    larry777 Posts: 480
    edited January 2011
    Yes,I did understand that cu ft comes into play with a decision to go Ultra or Select. My room is aprox 2600 sq feet. And my longer term plan was to add a power amp to power at least the front 3. based on this extra info, I should be ok with the SC-35 and THX Select then ?
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
    edited January 2011
    If I remember correctly THX select will deal with a room smaller than yours and Ultra is geared toward a 3000 cubic foot space. So probably Ultra in your case. You can probably google this, as suggested above.
    cnh
    edited January 2011
    dorokusai wrote: »
    I often sit in front of my Onkyo staring at the THX ULTRA logo and chanting AUM!
    Nothing has happened....yet?
    cnh
  • nguyendot
    edited January 2011
    cnh wrote: »
    cnh
    Select/2 is for 2000 cubic feet and smaller. Ultra/2 is for 4000 cubic feet and smaller.
    Your room is 2600 sq ft? What is it a warehouse? For one that large you're looking at a real Bona Fide THX (as in have lucasfilm come down and certify your room) certification.
    At that level you'd need THX speakers, cables, receiver, amps, etc to reach the 105db required by the standard.
    Main Surround -
    edited January 2011
    I'm pretty sure the OP means 2600 cu. ft. because, as you say 2600 sq. feet is over 50' x 50'...one hell of a ROOM!
    Which THX Certification Is Right For You?
    THX Ultra2
    THX Ultra2 Certified products bring the cinematic experience to larger home theaters, 3,000 cubic feet in size, with a viewing distance of 12 feet or greater from the screen.
    THX Select2
    THX Select2 Certified products are for medium sized rooms, up to 2,000 cubic feet in size, with a 10-12 foot viewing distance from the screen.
    THX I/S Plus Systems
    Certified Systems (AV Receiver + Speaker Bundle) have the power to fill a small home theater or dorm room where the viewing distance from the screen is 6-8 feet.
    THX Certified Multimedia Products
    THX Certified Multimedia Products are designed and engineered for PC gaming and multimedia on the desktop.
    cnh
  • larry777
    larry777 Posts: 480
    edited January 2011
    Sorry guys that should have read CU Feet and not SQ Feet. I remeasured, and the room is 2400 Sq Ft and not 2600. After considering other family members, the maximum volume will be about -15 and possibly down to -10 and in most cases above -15. thats why I was thinking the THX Select option of the SC-35 would be suitable for my room size. And as pointed out I will likely add an AMP for at least the front 3 later on if that matters. I also understand when playing below Reference Level that the THX Loudness Plus option will give you the same sound as recorded on the original soundtrack,but at a lower volume.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
