Question about CP/sent messages
drumminman
Perhaps it's an issue with my settings, but whenever I reply to a private message, the text of my reply doesn't appear as part of the message being replied to in my inbox, even though the original message is marked as being replied to by me. Except maybe once.
When I send a private message, nothing shows up in my sent message folder.
Can someone help me with this?
Thanks,
Fred
Thanks,
Fred
Post edited by drumminman on
Welcome to Club Polk Fred. Go to:
USER CP then SETTINGS & OPTIONS then EDIT OPTIONS
Then check the boxes and save and you should be good to go. -
I thought it might be something simple.
Fred"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
My **** has corn in it...
Spam Post reported and above TMPI! Eewwwww!
