10 guage or 12 guage wire
goldendomer
goldendomer Posts: 7
I can get my hands on some oxygen free copper 10 ga wire or belkin 12 ga wire for around the same price. i would need to add my own bananas but what do ya'll think. 10 or 12. i'm hooking up csi 30, fx1 30, and rti 150's
Post edited by goldendomer on
  • nemos2
    nemos2 Posts: 111
    edited February 2004
    I think that most everyone else will agree, go with the larger gauge wire ( the 10 gauge ). The more room the better.
    just my $0.02
    Polk LSi 15 Fronts
    Polk LSi C center
    Polk LSiFX Surrounds
    Outlaw Audio 990 Pre/Pro
    Outlaw Audio 755 amp
    Paradigm PDR-12 Sub
    Outlaw Audio Cables
    BetterCables Cables
  • Frank Z
    Frank Z Posts: 5,860
    I'd have to disagree. 12ga is fine for the mains, but 14ga is all you need for the surrounds.
  • walk
    walk Posts: 178
    I'd say the same. 12-ga is more than plenty. If you bi-wire the 150's it effectively doubles the wire gauge, also. I use 12-ga for the 150's low end and center channel (CSi30) and then 14-ga for the 150's high end and all the small surround speakers.
    - Sony 50"A3000 SXRD; Onkyo TX-SR 805
    - Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
    - Velodyne CHT-12 subwoofer
    VR3 Posts: 29,425
    I've used 12 AWG, and I've used 16 AWG, 15 AWG. Heres one thing to consider, the better quality the wire, even if it is smaller --- will suffice over cheap higher awg wire.
    15 AWG IXOS way outperforms 12 AWG HD.......
  • Frank Z
    A purely subjective opinion.
    VR3 Posts: 29,425
    I'm sure if you heard them side by side you would greatly agree. ;)
  • Frank Z
    Sid,
    I've listened to high end wire and cable before, IMHO there was no difference.
