Speaker wire + and -
peekobi
peekobi Posts: 58
Pay close attention to speaker wiring polarity. In other
words, connect positive (+) terminals only to positive
(+) terminals, and negative (–) terminals only to negative
(–) terminals. If you get them the wrong way
around, the sound will be out of phase and will sound
unnatural.
IS THERE AN EASY WAY TO TELL THE + FROM THE - ? Is the wire marked somehow? I'm using 16G Monster wire but I cannot tell + from -
Reciever Onkyo TX-SR708
Center - polkaudio CS245I
Mains -- polkaudio RT600I's
Sides -- polkaudio RT35's
Rears -- polkaudio RT25I's
Sub ---- polkaudio PSW-350
TV: Panasonic TC-P50GT30 HDTV
Blu-Ray Player Panasonic DMP-BDT215
Common sense ain't that common!:loneranger:
Post edited by peekobi on
    F1nut Posts: 51,763
    edited January 2011
    If this is the clear jacketed type wire there is no real positive or negative. What you will find is one side marked in some way, such as a white strip or a raised ridge running the length. Pick one side as positive and make sure you wire up everything the same way.
    txcoastal1 Posts: 13,512
    edited January 2011
    If its not blk/red...copper/silver....then there will be a ridge on one of the conductors when you split it just hook up the same ++...-- on each end
    edited January 2011
    you beat me to it
    treitz3 Posts: 19,989
    edited January 2011
    Jesse, I think the type he is talking about has one side that looks like copper wire or a copper tinted clear jacket and the other side has a metal (silver tint) look. Peekobi, just pick one for positive and the other for negative and keep it consistent throughout the entire rig.
  • peekobi
    peekobi Posts: 58
    edited January 2011
    will do. Its hard to tell the silver tint from the copper tint. I did notice a white stripe on one set. Thanks
  • halo71
    halo71 Posts: 4,631
    edited January 2011
    Got a multi-meter?
    --Gary--
  • peekobi
    peekobi Posts: 58
    edited January 2011
    I have a Radio Shack sound level meter. Is that what you mean?
