Mortite- Was it good for you?
Rev. Hayes
Rev. Hayes Posts: 475
edited January 2011 in Vintage Speakers
The Mortite Mod, a cheap tweak but is it worth it?
Obviously this poll is for those who actually tried this.
Sounds good to me...
Post edited by Rev. Hayes on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2011
    I tried it on my Baby Advent ii's made a huge difference in bass response.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Rev. Hayes
    edited January 2011
    edit: nevermind........
    F1nut Posts: 51,693
    edited January 2011
    Not worth it.
    heiney9 Posts: 25,408
    edited January 2011
    Worth it.
    mhardy6647 Posts: 34,930
    edited January 2011
    Moretite (or similar) helps damp resonance on certain ill-behaved cast metal horns...
    I also used it to damp the frame of Radio Shack 40-1354 5-1/4" fullrange twincone drivers. Not sure it actually helped, but it couldn't hurt. These have also had Dave Dlugos' (www.planetsofta.com) phase plugs. Enclosures were designed by Bob Brines (Brines Acoustics) and built by my woodworker/contractor friend Mike Berg. I was actually listening to these last night after a fairly long hiatus; they sound very, very good - single drivers cannot be beaten for imaging (albeit with a fairly narrow window).
  • Conradicles
    Conradicles Posts: 6,334
    edited January 2011
    I love mortite
    edited January 2011
    Can't vote here...have a box sitting in my office and a set of Monitor 5s that need sealing but have been too lazy to break out the old screwdriver and get the job done. So I'll have to report back. But I'm pretty sure it's going to be 'worth it' because they are not properly sealed at this point!
    cnh
  • DON73
    DON73 Posts: 516
    edited January 2011
    cnh wrote: »
    cnh
    Is there an easy way to tell if they are not properly sealed?
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • chandler9a
    chandler9a Posts: 878
    edited January 2011
    I have to say it was worth it for me. Did a pair of SDA 1.2 TL's, some SDA 2A's and some Monitor 5jr's and it helped all of them
    F1nut Posts: 51,693
    edited January 2011
    DON73 wrote: »
    Are your gaskets damaged? If not, you should have a good seal.
  • george daniel
    george daniel Posts: 12,096
    edited January 2011
    I am not allowed to own mortite anymore,,I'll stick with the stock gaskets and Larry's rings.
  • zingo
    zingo Posts: 11,258
    edited January 2011
    Mortite is a fine tweak for anyone wanting to spend some time with their speakers, but it wasn't a night and day upgrade for me. I will however be redoing my friend's Infinity RS 4.5s with Mortite as his current driver seals are all but disintegrated.
    As mentioned above, I've tried it for dampening before, but it's not worth your time.
  • DON73
    DON73 Posts: 516
    edited January 2011
    I haven't pulled the speakers out. I'm just going by the numerous posts here that say mortiting really improves the bass response.
  • schwarcw
    schwarcw Posts: 7,358
    edited January 2011
    I noticed an improvement with Mortite. Cheap, easy and worthy tweak.
    Carl
  • headrott
    headrott Posts: 5,496
    edited January 2011
    I did notice a very small improvement (so I answered yes), but vastly superior to the mortite are Larry's rings.
    The rings made a night and day difference in the sound.
    Greg
    F1nut Posts: 51,693
    edited January 2011
    DON73 wrote: »
    I found otherwise.
    I think the "positive" results that some have are due to the fact that the screws had loosened over the years. Of course, in applying the Mortite, the screws get tightened up. Therefore, I suggest tightening all the screws first.
  • fbm211
    fbm211 Posts: 1,488
    edited January 2011
    I too did not notice any difference with the mortite either.Waste of time IMO.
    The dynamat extreme tweak made a great improvement to the mids though.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • silvertuner
    silvertuner Posts: 496
    edited January 2011
    ehh, i use it to replace worn out gaskets, but i dont make it a necessary "mod" anymore unless i have to replace the worn out gaskets like i currently am on the crossovers on my altec's
    some cheap free sony speakers
    psw125
    denon 1610
    3.1 channel because i hate cables ran across the living room like that
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    I liked the results on the vintage polk drivers with stamped steel baskets. I wouldn't bother with any cast basket drivers. Yes I did tighten all the screws on my drivers and had no air leaks.
    Ben
    Ben
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    I found there to be a HUGE improvement after applying Mortite. It definitely wasn't due to the screws being loose, as F1 alluded to above. All of my drivers had been checked for tightness multiple times before I ever applied Mortite to them. My gaskets were in fine shape too, as far as I could tell.
    Bass output was vastly improved, overall midrange clarity was much better...the midrange seemed to come more forward in the mix, and blended with the highs and lows much better. This mod is an absolute no-brainer IMO. I'll never own another pair of vintage Polks without Mortiting them.
    Jesse-Have you ever tried Mortiting your speakers? I seem to recall you mentioning a while back that you just didn't feel it was necessary, so you never tried it.
    I seem to recall that using Mortite was actually a Polk Audio suggested tweak too.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    Toolfan66 Posts: 17,994
    edited January 2011
    It's a cheap "mod/tweek" try it and see for yourself, all my SDA's have mortite..It's a hobby try it you just might like it..
    Just keep your old gaskets..
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2011
    I know I'm probably out of line here,but I can't help but wonder what's up with the red letter title under CC's name? A time-out maybe?
    Sorry for the derail,back to Mortite
  • comfortablycurt
    edited January 2011
    Huh?
    I don't see anything under my name...:confused:
    edited January 2011
    Curt was mistakenly "banned" for a short period. It was an error by the mods as I believe he quoted a spammers post and somehow was automatically banned when the spammer was banned.
  • comfortablycurt
    edited January 2011
    heiney9 wrote: »
    Interesting...I hadn't even realized that happened.:confused: I guess I'll have to remember not to quote spam posts when I report them from now on.
  • thsmith
    thsmith Posts: 6,082
    edited January 2011
    I saw some improvement but the stress it put on the screws concerned me and went back to gaskets and now Larry's steel rings which gave me the best bass response and piece of mind.
    edited January 2011
    thsmith wrote: »
    Brings up a good point, using Mortite without flattening it out one needs to be careful when reinstalling the screws. If done carefully and tightened diagonally there should be no issue.
    Sometime before the end of the month I'll be putting Larry's rings in my 5B's so that will be documented as well as the listening observations. Only real problem is I have a new computer with new sound card option's (USB) so I need to become familiar with the new system before making a change like this or my observations will be skewed.
  • Mike Reeter
    edited January 2011
    I thought something was up....now back to our regular scheduled programming.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2011
    Rev. Hayes wrote: »
    But I have 4 set of Mortited Polks and could only vote "Yes" once :biggrin:
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2011
    . . . a "good" seal, or an "excellent" seal ??
    NAD SS rigs w/mods
    GIK panels
