What is my weakest link?
    edited January 2011
    Fongolio wrote: »
    (Hoddy toddy female British accent) YOU are the weakest link. Good bye.
    I can't believe it took 29 posts! I'll give Larry 6 points for effort though.
    Easy there charm school.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    Sorry Larry I missed your post:redface:
    Ben
  • Hoochespice
    Hoochespice Posts: 1
    edited January 2011
    This was refreshing. I wished I could read every post, but i have to go back to work... But I'll be back.The titan roms were pretty easy to figure out! led watch
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    Reported.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • comfortablycurt
    edited January 2011
    One of your weak links is definitely the fact that you're mixing SDA's and LSi's with a CSiA6 center. That's a pretty wide array of VERY different sounding speakers.
    I also think those LSi15's are basically being wasted as surrounds. Those are some excellent sounding speakers, and in the surround position they're hardly even being used. Personally, I'd move the LSi15's up front in the HT, and get an LSi series center and surrounds. Then move the SDA's to the 2 channel rig, or get rid of them altogether and get something else. It sounds like you're ready to move on to something else aside from SDA's...so by all means do it! If you ever decide that you miss the SDA's, it'll be easy enough to find another pair.
    nooshinjohn Posts: 26,002
    edited January 2011
    The CSiA6 is the recommended center for the SDA's, and that is about the only way to go there. It was my intent to replace the SDA's with the LSI's, but they just don't sound as good to my ear, and were placed in the surround spot instead. They do perform well in that position, far better than anything else I have tried there.
    HT however is the least of my concerns as the only time itgets used is when I am watching tv or the occasional movie. Where I really want to improve things is in two channel listening, and with my move about 4 months off, I want to start planning early.
    edited January 2011
    If 2 channel is your main concern, then it may be time to move on from the SDA's. Lots of good sounds out there from a variety of speakers.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2011
    CSiA6's may be the best match of the recent centers, but I'd think the older CS350 or 400 would be a better overall SRS match... but none of the three are a good front stage match for the 15's.
    SDA's over 15's up front would be my preference as well. I find the whole LSi line too laid back to engage me. My SRS's, even with their cursed, tweeters from hell (the original SL2000's), do me just fine. May be the case with you as well...
    What else have you tried as surrounds? Other full range towers? Bookselves? If the latter, it would not be surprising that the 15's are most pleasing to date...
    More later,
    Tour...
    Vox Copuli
    edited January 2011
    I have run TSi 100's and the Monitor 50's in the surround slots. they replaced my Energy Take5 set. They were the first things to go in my setup as my old Yamaha RX-v2090 blew those things apart in less than a nanosecond.
    heiney9 Posts: 25,497
    edited January 2011
    tonyb wrote: »
    I don't agree that SDA's are a weakness in a 2ch set-up. Now if he had asked about wanting to try a speaker with a different presentation then one could say Maggies or whatever.
    Maggies as well as other designs of loudspeakers aren't without their deficiences as well. The SDA is not a weak link, but if one wants to try something different then have that be the reason to swap speakers.
    SDA's get better and better as the gear gets better and better so they are not a "weakness" in my mind.
