Reaity Cables
Pycroft
Pycroft Posts: 1,961
edited January 2011 in 2 Channel Audio
Any comments on these cables?
http://www.realitycables.com/products_pricing.html
Speaker cables - not interconnects. I'm curious. Thanks,
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
    heiney9 Posts: 25,398
    edited January 2011
    Probably waht you'd see if you looked under the sheathing of Signal Cables. They sure don't go into in detail about why their's are better or how they are made............unless I missed it. Vampire is good stuff, no doubt, but I don't see anything that makes these any better than Canare or Signal for example.
    tonyb Posts: 33,065
    edited January 2011
    I use these, in bi-wire form. Can't say how they compare to other big boys, but they do sound pretty darn good. They have a good following over at AVS forum. They are thick, not very flexable either so tight spots maybe a problem. They gel pretty good with my system,great low end, nice airy top. I paid I think 350 for a 10 ft pair bi-wired, couldn't be happier with the sound. Great budget cable imho.
  • marvda1
    marvda1 Posts: 4,936
    edited January 2011
    Puritan PSM156
    tonyb Posts: 33,065
    edited January 2011
    Let me add that Gregg is a great guy to deal with. He's local to me and even offered to hand deliver,install for me. Told him I thought I could handle it.:tongue: He's also not a big fan of bi-wired cables even though I made him make me a set, don't regret it either.
  • Face
    Face Posts: 14,340
    edited January 2011
    They sound good.
