Mortiting
DON73
DON73 Posts: 516
edited January 2011 in Vintage Speakers
I bought some mortite last week thinking about doing some Monitor 7s. The mortite I got is a wide strip made up of several smaller strips that can be peeled off. Do I just place a ring of the stuff under the speaker flange or flatten it out and apply.
When I was about 20 I made pretty good money off people who got tinkeritis and tried working on their cars. I don't want to end up like them with a distorted speaker flange because I used too much mortite. Thanks.
TO ERR IS HUMAN. TO FORGIVE IS CANINE.
Post edited by DON73 on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2011
    Take 2 strips of the mortite and put it between wax paper and roll it out flat as you can with a rolling pin (if your SO will let you) or a laminate roller. Put it around the rim of the driver flange and cut out the mortite in the screw holes and pop it in and tighten it up.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    Scott
    Really? I never flattened mine out before applying it to my speakers. I haven't heard of anyone else doing that either.....I also honestly think you'd get a better seal with a single bead than would with two beads, because it can settle more completely and uniformly with just a single bead.
    When I put it on, I just applied a single bead of it to the back of the flange and on the inside edge of the screw holes all the way up against the basket, and re-installed the drivers. You don't want to tighten the drivers down all the way the first day though. Get them pretty tight, without killing them...and let it settle for a day. Give each screw another turn or so for the next few days until the Mortite seems to have settled completely.
    It seems to me that you'd get a much better seal this way than you would flattening it out first.
    Just be careful not to over tighten it right off the bat. The Mortite takes a little while to settle, and if you over tighten it right off the bat it can bend the basket.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • MillerLiteScott
    edited January 2011
    Trust me roll out 2 strips. Much better.
    Jesse gets the credit for this method.
    Scott
    heiney9 Posts: 25,432
    edited January 2011
    I never rolled it out (good idea though) once I seated the driver I applied even pressure on the driver basket to flatten it out before tightening the screws. Then every few day for a couple weeks I checked and tightened the screws accordingly.
    The next time I use it I will pre-flatten it simply because it reduces the risk of distorting the driver basket and/or stripping the screw holes in the cabinet.
  • DON73
    DON73 Posts: 516
    edited January 2011
    Thanks for the information everyone. The thing I was most concerned about is the chance of distorting the basket. You have given me the info I need to avoid that.
    F1nut Posts: 51,778
    edited January 2011
    First, let me say that unless your stock gaskets are damaged or missing I see no reason to use Mortite.
    Do it like Scott said, roll out two strands together. This should end up being about 1/32" thick and will be the same width as the speaker flange. Interestingly, after tightening down the screws it ends up being the same thickness (1/64") as the stock gaskets.
    I compared the sound using the stock gaskets verses using the Moritite. I found that the bass response was better using the stock gaskets and threw the Mortite in the trash can.
    All that said, nothing beats a set of Larry's rings.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    I didn't like the mortite tweak on my M7's either. I bought some gasket material at the auto parts store that comes in an 18" wide roll, then used a compass to mark out and cut new circular gaskets for the drivers. Works great and better couples the drivers to the front.
    DKG999
    edited January 2011
    I had great results with Mortite, but I have Larry's rings to install in both my M5's and 1C's so it's a moot point for me. My guess is, in reality, it's somwhere in the middle of people who think it stinks and people who think it works great.
  • Rev. Hayes
    Rev. Hayes Posts: 475
    edited January 2011
    I didn't care for the mortite either. I didn't note any improvement over stock and the stuff is a mess if you are going to take the driver out more than once.
    Hmmm...
    I think a poll may be in order. I'm on it.
    Sounds good to me...
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    If you have a good compass, such as the compass points that fit on a 12" metal ruler, and an exacto knife, then using some good gasket material is quicker than the mortite, even with the non-circular shapes for the tweeter and terminals. You can get good 1/64 and 1/32 gasket material at auto parts stores, I paid $7.99 for a role that would do several sets of monitors or SDA's.
    Larry's rings are a great idea. Overkill for my M7's in a vintage system, but worth it if you are using monitors or SDA's for your primary speakers, IMHO.
    DKG999
  • DON73
    DON73 Posts: 516
    edited January 2011
    Anyone want to buy a new roll of mortite.......will trade for gasket material:biggrin::biggrin:
    edited January 2011
    Or after 11 posts (hardly enough to persuade or dissuade) you could try it yourself and make up your own mind.
  • DON73
    DON73 Posts: 516
    edited January 2011
    heiney9 wrote: »
    I'll probably try the new gasket first and then the mortite. How can I tell if the boxes are not sealed properly? I've tried the push test and the mid moves freely and returns slowly.
    F1nut Posts: 51,778
    edited January 2011
    You are fine, no need to do anything else.
