4 speakers, 2 channel amp
deathjunior
Alright so im rebuilding my entire stereo system in my grand prix.
For the subs im going both spl and sq so those will be dual RE audio SEx subs. The amp powering them will be an MTX JH1200 running at 1 ohm. I know that will be okay and it should be easy to run. However I am having trouble deciding on powering my speakers. The speakers up front will be a set of dxi 6.5 components in kick panels and a set of db 5.25 components in the doors. Then for the rear deck ill be using 6x9 dxi's and 4 inch dxi's. The problem im running into is going to be powering the speakers. Ive got 3 options, i can run two PA330 amps then just run the speakers in paralel one amp for fronts and one for backs(this will be the cheapest by far). I can run 4 PA330 amps(not bad but it isnt cheap and the 4 inch dxi's cant handle more than 45 rms watts and thats 30 less than the amp will put out). The last option is running two PA660's (the problem here is the same as the first but i can get two of the PA330's for less than one PA660)
What should i do?
What should i do?
Post edited by deathjunior on
Good idea but what i didnt mention is that i work at best buy and polk audio has an accommodation for the workers there so i get my entire set of speakers and amps for less than one set of MM components. So im kinda stuck with DXI's
Can you get the same "killer" deal on MM?2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
deathjunior wrote: »Good idea but what i didnt mention is that i work at best buy and polk audio has an accommodation for the workers there so i get my entire set of speakers and amps for less than one set of MM components. So im kinda stuck with DXI's
unless you're getting an 8ch processor for free, there is no point running 5 set of speakers. -
Na i can only get the accommodation on select polk speakers and amps we sell at best buy so the mm's are out of the question on it. Its an accommodation polk does for many of its retailers. So im stuck with the subs and amps i can get. As for running the 4 sets of speakers. Im deffinetly running speakers to fill the stock speaker slots first of all, so im going to run the 6x9's and the 4's in the rear deck no matter what. As for the front speakers i know the 6.5's can reach lower tones than the 5.25s but i still want a set in the doors and i dont want to have to modify the door's to much because i want to be able to replace the stockers if i have to. So the kick panels from q logic will house the 6.5's and thier tweets. As for the 5.25's ill run the 5.25 woofers in the doors and ive got a second set of sail panels for the car and ill drill holes and mount those tweets in them.
If you're going to put alot of work/effort into creating this setup, why not do it right and spend a little extra $$ on better components?
Having just 1 set of components to power will just leave you cash to get an even better amp for them as well. The extra headroom is always a plus.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
It would probably be A LOT of extra money. Accommodation purchases are usually 1/4 of retail price.
exalted512 wrote: »It would probably be A LOT of extra money. Accommodation purchases are usually 1/4 of retail price.
-Cody
Geez, that much savings?
I withdraw my statement
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Alright so back to the idea now that exalted explained it a little better lol, like i said i can pick up all 4 speakers and two PA330 amps for less than one set of the mm components, i know there a great set of speakers, but i dont get the accommodation on em so what should i do wiring wise. Would i just run one power wire to the positive side on the first crossover and the ground to - of the first crossover, then just run power and ground from one crossover to the other? Thad be parralel
