Can this Vifa Tweeter be beat for the cost?
Conradicles
Conradicles Posts: 6,344
edited January 2011 in DIY, Mods & Tweaks
Here is the tweeter I am thinking of using for a project:
https://www.madisound.com/store/product_info.php?manufacturers_id=153&products_id=1181
For $37 each, can I do better? Crossover point is around 1800 - 2000
Thanks folks,
Eric.
Post edited by Conradicles on
  • Face
    Face Posts: 14,340
    edited January 2011
    That's one of the best choices for under $50.
    Are you going active or passive? What kind of slopes? If passive, unless you go very steep, you'll need a zobel to knock out the hump at it's FS.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    That Vifa would be good,here are a few other good choices for under $50. All will work perfectly fine down to 1.8k.I use the SEAS H1212 with an active xover at 2k and it is the best metal dome I have heard.
    https://www.madisound.com/store/product_info.php?cPath=45_229_250&products_id=795
    https://www.madisound.com/store/product_info.php?cPath=45_229_324&products_id=8823
    http://www.solen.ca/pdf/sb/sb29rdcnc0004.pdf
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    What woofer are you going to use?
    Ben
  • Conradicles
    edited January 2011
    Thanks guys and I am a bit of a rookie so Face you spoke over my head LOL.
    Here is what I am doing so bare with me:
    I have 2 sets of Klipsch KG2's...one pair kind of used the other pair mint. These little bookies produce huge bass and I love them for that. I am going to use one pair of these for a modest 2-channel rig and save up for some LSi's.
    I already bought cap and resistors (Dayton's and Mills) and some nice Sanus stands. To upgrade the tweeters Bob Crites said he would charge $58 shipped for titanium diaphrams.
    Then I got to thinking, I could try a different tweeter just for giggles.
    So I already have the enclusure with the 8" woofer with a 10" passive and plenty of room for a new tweeter.
    But Face you got me thinking it is much more complicated. The speakers are 4 ohm, as well is the tweeter and they are rated 90 db.
    Jsut looking to have a little fun and try to improve the sound a bit.
    Help!!!
  • Face
    Face Posts: 14,340
    edited January 2011
    If what I said was over your head, order the Bob Crites diaphragms.
  • Conradicles
    edited January 2011
    The crossover uses a 3 ohm resistor, 4uf cap, 8uf cap and 24uf cap.
    Can the exact crossover frequency for the tweeter be determined by these values?
  • Face
    Face Posts: 14,340
    edited January 2011
    Not without having electrical and acoustic measurements of the driver in question.
  • 20hz
    20hz Posts: 636
    edited January 2011
    Thanks folks,
    Eric.
    I was higely recomemded those but the faceplate was huge so I found these the vifa xt25sc90-04 PE#264-1014 at only $20 each , I realize it may not be as good but w/a 5" that cant put out the major db it should be a decent setup (plus it fits better) .
  • Face
    Face Posts: 14,340
    edited January 2011
    The tweeter in the first post doesn't have a huge face plate, it uses the standard size for most aftermarket tweeters.
  • Conradicles
    edited January 2011
    Yes I canceled this project anyway with the addition of my new LSi9's!
