Onkyo back with giant amp w/ power meters & $1.5K CD player
Danny Tse
From TWICE....
Check them out here
Las Vegas - Onkyo is going retro, expanding its selection of stereo component separates with three models whose styling is reminiscent of the brand's 1980s models but whose technology is from the 21st Century.
The three components are the $1,699-suggested P-3000R pre-amplifier, $2,499 M-5000R power amplifier, and $1,499 C-7000R CD player. All will be available this month through select dealers.
All of the separates feature new Dynamic Intermodulation Distortion Reduction Circuitry (DIDRC) to prevent high-frequency interference above 100kHz, which is beyond the range of human hearing but which are susceptible to clock pulses and other types of distortion that can generate "beat interference," which "affects the character or atmosphere of the original sound," the company said. DIDRC is incorporated into the amplification circuitry of the three hi-fi components.
To further reduce interference, the products feature separate digital and analog circuits.
Other features include such audiophile-grade parts as massive toroidal transformers. A new circuit board construction and separate chassis panels are designed to eliminate unwanted vibrations.
The P-3000R pre-amp accepts analog sources as well as digital sources via AES/EBU digital connectors and a USB input. A high-quality 32-bit Burr-Brown DAC is used for each channel and the component can be bi-amped.
The M-5000R amp offers large front-panel analog power and high-current capabilities. AWRAT amplification design consists of DIDRC technology along with a low NFB design, closed ground-loop circuits, and high instantaneous-current capability.
It's rated at 2x80 watts into 8 ohms using FTC standards, but it can also drive demanding complex-impedance loudspeakers to high levels with a dynamic power rating of more than 450 watts into 1 ohm, the company said. Power efficiency is enhanced via a three-stage inverted Darlington circuitry and a new quad push-pull amplification design that uses two extra transistors for each channel. An XLR input opens makes it possible to double power output via a BTL (bridged transless) set-up.
The C-7000R CD player uses a thermally regulated clock with crystal oscillator to reduce potential interference. Also to reduce potential interference, the player can be operated in analog-only or digital-only mode, with analog and digital circuitry physically separated.
Check them out here
Post edited by Danny Tse on
That is what I'm talking about!!! Thanks for the info.
Looks nice. Love those big analog meters.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
WOW.
That is some BEAUTIFUL gear.
I think I have a woodie.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Very nice.Looks very similar to my fave vintage Technics SEA3 / 5
ahhh, a newer version of my M504....well kinda...:biggrin:--Gary--
I'm with you there. As the owner of an Integra P-304 pre-amp. I'm digging the RETRO look of the power amp!
cnh
I think you should send that 304 my way! :biggrin:--Gary--
Very nice looking gear!Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I'm a little surprised at the amp specs, but at least it seems they made damn sure it would handle lower ohm loads...I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
So, Ben, going to change your whole "I'll never buy a 2K amp ever" statement???
nice look, interesting on the specs on the amp as well but 1 ohm stable is good good good. I didn't see what the peak amps are for it though. -
Well, I guess the car industry has benefited from new technology and old styles, why can't audio?? I kinda like the look too!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
cnh
I remember that preamp
That does look like VERY cool gear. I love the retro look
James2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player -
Add tubes and it will be Great.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
James
You ought to know, James. It's a solid performer. Can't wait to invest in a TT for it as I haven't heard that section of the pre yet.
DisneyJ's also got a point above!
I love this time of year...after the Holidays of taking care of the family, and the hustle and bustle then its gear time CES...then there ISC West for work...but I like it.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Love the meters on amps.
Maybe my Soundcraftsmen will come back in style. (If it ever went out of style.)
From a time when amps looked like amps:>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Oh, i'll buy a $2k amp, i just won't pay that for it. I'll wait this one out and see what happens. I've got a major hard-on for that thing.
Except the 504 was 2x the power.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
2K for 2x80 ?
Take a gander at the rest of the information on the amp. It's a bit more interesting than that.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
True, but I never associated higher power to higher quality. Although the 504 was around $900 new if I remember right. hummmm....lol--Gary--
I think it was closer to $650. I remember choosing between the Onkyo, an Adcom 555, and a Denon POA-2400 back in '88 or '89. I remember the Adcom and Denon were both more expensive at $750 each, of course they had a little more power as well. -
Damn crooks at Custom Audio.
Wonder if they are still around in Little Rock.....--Gary--
I had a integra amp. It was rated at 100 per, I think it was 1030 or 5030 i can't remember the model number now. IT was a darn good sounding amp and held it's own against many over the years. I sold it last year but it did serve me well for at least 10 years.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I like them!! That amp's awesome looking...gotta dig the big analog meters!The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I took a gander, Nothing too impressive. So what that it goes down to 1ohm, I'm sure I can find something much better for 2K
Then don't buy it?
In your personal experience, what didn't you like about the amp? I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
2K for 2x80 ?
There are far more expensive amps than that, with far less wattage.The nirvana inducer-
Love the retro look with meters, instead of just a black face panel.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
I was thinking the same thing.
Can't read the print on the amp's meter covers, but if it says "VU" I'm in retro heaven - regardless of what's behind the glass.Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2
