Onkyo back with giant amp w/ power meters & $1.5K CD player
Danny Tse
Danny Tse Posts: 5,206
edited April 2011 in 2 Channel Audio
From TWICE....
Las Vegas - Onkyo is going retro, expanding its selection of stereo component separates with three models whose styling is reminiscent of the brand's 1980s models but whose technology is from the 21st Century.
The three components are the $1,699-suggested P-3000R pre-amplifier, $2,499 M-5000R power amplifier, and $1,499 C-7000R CD player. All will be available this month through select dealers.
All of the separates feature new Dynamic Intermodulation Distortion Reduction Circuitry (DIDRC) to prevent high-frequency interference above 100kHz, which is beyond the range of human hearing but which are susceptible to clock pulses and other types of distortion that can generate "beat interference," which "affects the character or atmosphere of the original sound," the company said. DIDRC is incorporated into the amplification circuitry of the three hi-fi components.
To further reduce interference, the products feature separate digital and analog circuits.
Other features include such audiophile-grade parts as massive toroidal transformers. A new circuit board construction and separate chassis panels are designed to eliminate unwanted vibrations.
The P-3000R pre-amp accepts analog sources as well as digital sources via AES/EBU digital connectors and a USB input. A high-quality 32-bit Burr-Brown DAC is used for each channel and the component can be bi-amped.
The M-5000R amp offers large front-panel analog power and high-current capabilities. AWRAT amplification design consists of DIDRC technology along with a low NFB design, closed ground-loop circuits, and high instantaneous-current capability.
It's rated at 2x80 watts into 8 ohms using FTC standards, but it can also drive demanding complex-impedance loudspeakers to high levels with a dynamic power rating of more than 450 watts into 1 ohm, the company said. Power efficiency is enhanced via a three-stage inverted Darlington circuitry and a new quad push-pull amplification design that uses two extra transistors for each channel. An XLR input opens makes it possible to double power output via a BTL (bridged transless) set-up.
The C-7000R CD player uses a thermally regulated clock with crystal oscillator to reduce potential interference. Also to reduce potential interference, the player can be operated in analog-only or digital-only mode, with analog and digital circuitry physically separated.
Check them out here
Post edited by Danny Tse on
  • Conradicles
    Conradicles Posts: 6,335
    edited January 2011
    That is what I'm talking about!!! Thanks for the info.
  • Earthy
    Earthy Posts: 488
    edited January 2011
    Looks nice. Love those big analog meters.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • concealer404
    concealer404 Posts: 7,440
    edited January 2011
    WOW.
    That is some BEAUTIFUL gear. :smile:
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2011
    I think I have a woodie.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Very nice.Looks very similar to my fave vintage Technics SEA3 / 5
  • halo71
    halo71 Posts: 4,630
    edited January 2011
    ahhh, a newer version of my M504....well kinda...:biggrin:
    --Gary--
    edited January 2011
    halo71 wrote: »
    I'm with you there. As the owner of an Integra P-304 pre-amp. I'm digging the RETRO look of the power amp!
    cnh
  • halo71
    halo71 Posts: 4,630
    edited January 2011
    cnh wrote: »
    cnh
    I think you should send that 304 my way! :biggrin:
    --Gary--
  • coolsax
    coolsax Posts: 1,826
    edited January 2011
    Very nice looking gear!
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • concealer404
    edited January 2011
    I'm a little surprised at the amp specs, but at least it seems they made damn sure it would handle lower ohm loads...
  • cstmar01
    cstmar01 Posts: 4,424
    edited January 2011
    So, Ben, going to change your whole "I'll never buy a 2K amp ever" statement??? :tongue:
    nice look, interesting on the specs on the amp as well but 1 ohm stable is good good good. I didn't see what the peak amps are for it though.
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2011
    Well, I guess the car industry has benefited from new technology and old styles, why can't audio?? I kinda like the look too!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Pycroft
    Pycroft Posts: 1,961
    edited January 2011
    cnh wrote: »
    cnh
    I remember that preamp :)
    That does look like VERY cool gear. I love the retro look :)
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2011
    Add tubes and it will be Great.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited January 2011
    Pycroft wrote: »
    James
    You ought to know, James. It's a solid performer. Can't wait to invest in a TT for it as I haven't heard that section of the pre yet.
    DisneyJ's also got a point above!
    cnh
    txcoastal1 Posts: 13,502
    edited January 2011
    I love this time of year...after the Holidays of taking care of the family, and the hustle and bustle then its gear time CES...then there ISC West for work...but I like it.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2011
    Love the meters on amps.
    Maybe my Soundcraftsmen will come back in style. (If it ever went out of style.)
    From a time when amps looked like amps:
  • concealer404
    edited January 2011
    cstmar01 wrote: »
    Oh, i'll buy a $2k amp, i just won't pay that for it. I'll wait this one out and see what happens. I've got a major hard-on for that thing. :tongue:
  • erniejade
    erniejade Posts: 6,321
    edited January 2011
    halo71 wrote: »
    Except the 504 was 2x the power.
  • concealer404
    edited January 2011
    Lasareath wrote: »
    2K for 2x80 ?
    Take a gander at the rest of the information on the amp. It's a bit more interesting than that.
  • halo71
    halo71 Posts: 4,630
    edited January 2011
    erniejade wrote: »
    True, but I never associated higher power to higher quality. Although the 504 was around $900 new if I remember right. hummmm....lol
    --Gary--
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited January 2011
    halo71 wrote: »
    I think it was closer to $650. I remember choosing between the Onkyo, an Adcom 555, and a Denon POA-2400 back in '88 or '89. I remember the Adcom and Denon were both more expensive at $750 each, of course they had a little more power as well.
  • halo71
    halo71 Posts: 4,630
    edited January 2011
    WilliamM2 wrote: »
    Damn crooks at Custom Audio. :tongue:
    Wonder if they are still around in Little Rock.....
    --Gary--
  • erniejade
    edited January 2011
    I had a integra amp. It was rated at 100 per, I think it was 1030 or 5030 i can't remember the model number now. IT was a darn good sounding amp and held it's own against many over the years. I sold it last year but it did serve me well for at least 10 years.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2011
    I like them!! That amp's awesome looking...gotta dig the big analog meters!
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • concealer404
    edited January 2011
    Lasareath wrote: »
    I took a gander, Nothing too impressive. So what that it goes down to 1ohm, I'm sure I can find something much better for 2K
    Then don't buy it? :confused: In your personal experience, what didn't you like about the amp?
  • comfortablycurt
    edited January 2011
    Lasareath wrote: »
    2K for 2x80 ?
    There are far more expensive amps than that, with far less wattage.
  • TORI3
    TORI3 Posts: 234
    edited January 2011
    Love the retro look with meters, instead of just a black face panel.
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2011
    FTGV wrote: »
    I was thinking the same thing.
  • Gulfstrings
    Gulfstrings Posts: 313
    edited January 2011
    Can't read the print on the amp's meter covers, but if it says "VU" I'm in retro heaven - regardless of what's behind the glass.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
