Mediocre sound
LitoZacky
LitoZacky Posts: 115
edited January 2011 in Troubleshooting
Even for LSi-15 with enough juice, I still feel like I'm hearing mediocre sound quality. Computer -> AVR -> AMP -> Lsi-15 (AQ type 4 cables)
My suspicion for the poor sound is I'm lacking a good DAC. My theory is speakers are the producer of sound, how good the sound is depends on the source. I'm close to purchasing an EE minimax dac or W4s dac 2. Could someone show me what I'm doing wrong, thanks.
part of the poor sound is the harsh ear piercing trebles.
Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus
Post edited by LitoZacky on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    The W4S is much better than the EE. There's a very good writeup on it in the latest issue of The Absolute Sound. Good luck.
  • LitoZacky
    edited January 2011
    If you had compared both then I don't doubt your judgment, but if you haven't then there's a possibility that you're under-rating the minimax. I heard the w4s is an amazing dac at clarity retrieval, I'm still finding my way into the audio world but so far I'm starting to like warmth sound. I prefer warmth over clarity. If the w4s had sticking a tube in there somewhere that would've been a big +
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • dorokusai
    edited January 2011
    LitoZacky wrote: »
    If you had compared both then I don't doubt your judgment, but if you haven't then there's a possibility that you're under-rating the minimax. I heard the w4s is an amazing dac at clarity retrieval, I'm still finding my way into the audio world but so far I've starting to like warmth sound. I prefer warmth over clarity. If the w4s had sticking a tube in there somewhere that would've been a big +
    Your one of those tube is needed folks, so sorry I can't help you anymore. Eventually you'll figure out the right combination. Good luck.
    edited January 2011
    If that's the case, you might want to run this by Brock, H9, because he's currently experimenting with DACs and the like, and also into tubes.
    cnh
  • messiah
    messiah Posts: 1,790
    edited January 2011
    Get a better amp, maybe a Parasound.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • LitoZacky
    edited January 2011
    I didn't know an amp makes that much of a difference. I will look into parasound and sunfire
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • Phil Dawson
    Phil Dawson Posts: 288
    edited January 2011
    What is your source material? You say you are using your computer. If you are playing MP3 files that could be the cause of your problems. MP3 is a mediocre format at best. Phil
    SRS-SDA Front
    2 cs400i Center
    SRS-SDA Rear
    Shure 12in sub
    B&K ref 10 pre-pro upgr to ref 50
    Techniques 1200 TT
    Mac MR71 Tuna
    Lexicon rt-20 uni player
    PSE Studio pre for TT
    2 PSE Studio Mono Blocks
    4 PSE Studio Stereo Amps
    1 Mac 2100 Amp (bridged to mono) for sub
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2011
    ^ exactly; what's your source media?
  • fishbones
    fishbones Posts: 947
    edited January 2011
    LitoZacky wrote: »
    ...Or B&K (which tend to be warmer sounding). You would want one of the 200watt models to really bring those LSI's to fruition, since the lower wattage B&K's are half the current (200.2, 2220, 4420, EX442 would be the ones to look out for) But, alot of your problem most likely is using the DAC in your receiver. Getting a dedicated DAC should improve it alot!
    ...and what Phil said.
    I would do the amp after you get a DAC, IIWM.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2011
    LitoZacky wrote: »
    Interesting theory. :rolleyes:
    As others have said, you need to start with lossless files. Then you need to get the lossless files out of the computer with zero errors, and no jitter. Then you need a good cable to connect to a good DAC. After that, you need good cables to connect to a good pre-amp. After that, you need good cables to connect to a good amp. After that, you need good cables to connect to good speakers. Then you will have good sound.
    In the future, replace the "good" components with "great" components, and you will have great sound.
  • LitoZacky
    edited January 2011
    I connect pc to receiver with optical cable. I play FLAC/APE only using foobar. I tried wasapi for foobar but didn't really hear a noticeable difference.
    Speaker: LSi 15
    Amp: Emotiva XPA-2
