Programming Digital Subchannels
djseafood
djseafood Posts: 73
edited January 2011 in Electronics
I can't seem to figure out how to do this on my older Toshiba. It's a 30HF84 is HD ready and has an ASTC tuner but there is no way for it to find the over-the-air digital channels since they all have a decimal value (e.g. "2.1, 2.2, 4.1, 4.2")
Any ideas on how to get my TV to see these over the air digital subchannels?
Thanks,
AJ
HT
Receiver: Onkyo TX-SR506
FR: Polk Monitor 40
CNTR: Polk CS2
Sub: Polk PSW505
RR: Infinity SS2001 w/ SpeakerCraft 5.25" aluminum woofers and 1.5" ports
Patio: Polk Atrium 45
TV: Sony Bravia KDL-46XBR9
BD: Sony BDP-S570
Gaming: PS2 and Wii
PWR: APC C-5
Work
Receiver: h/k AVR 20
CD: marantz Professional PMD320
Mains: Infinity SS2005
2nds: DLK 1 1/2's
CNTR: Infinity Sterling Video
Subs: Paradigm PS-1000 w/ beefed up power circuit resistors and custom 15" w/ Polk PSW-505 amp.
Post edited by djseafood on
  • vmaxer
    vmaxer Posts: 5,120
    edited December 2010
    I've had the same problem. I just gave up:mad:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • djseafood
    djseafood Posts: 73
    vmaxer wrote: »
    Well damn! I was all excited I got a response already. I'm sure Toshiba support will be...well, anything but supportive!
    Thanks for the quick post!
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
    You may need one of those digital conversion boxes that run like 40 bucks or so.
  • Glowrdr
    Glowrdr Posts: 1,103
    What Tony said.
    Just found this - Consumer Alert: This component has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation's transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    Good call, back then when they said "HD ready", they still had analog tuners but if hooked to a cable box or satelite dish, then those boxes became the tuner.
  • djseafood
    djseafood Posts: 73
    edited January 2011
    Thanks for the help guys! I thought I saw somewhere that it had a QAM and ATSC tuner but I must have been mistaken. I think I glossed over the description on Amazon which stated it transmits ATSC over HDMI. Should have read more carefully! :redface:
    Anyway, on to search for a digital tuner now. Thanks again :)
    HT
    FR: Polk Monitor 40
    CNTR: Polk CS2
    Sub: Polk PSW505
    BD: Sony BDP-S570
    Gaming: PS2 and Wii
    PWR: APC C-5
    Work
    2nds: DLK 1 1/2's
