USB to S/PDIF high quality conversion
heiney9
heiney9 Posts: 25,511
edited January 2011 in 2 Channel Audio
My old Dell finally died, well the power supply did. At the time I was using Windows XP and I had trouble getting my new USB dac to work as the driver wasn't loading properly. So I gave up and set the dac aside and continued to use the optical out on the soundcard.
The new Dell uses Windows 7 and viola, hooked up the USB dac and it automatically installed the USB driver and the USB dac works. Great! Except I'm not sure the USB dac sounds as good as the AMC DAC-8 I've used for the past 5 years. Obviously the soundcard on the new Dell doesn't have a digital out so I have no way to hook up the external AMC dac.
So here's the question. Anyone have any experience or suggestions for a USB to S/PDIF converter, something that's audiophile quality? I've found a few.
Trends Audio
Tera Dak
Firestone
The dilema is I don't want to spend a whole lot of money and I want to have decent sound. I'm also not looking to add a soundcard to the new Dell that has a digital out unless that's a last option.
I am going to roll some op-amps in the USB dac I have to see if I can get it to sound closer to what the AMC DAC-8 sounds like but if that doesn't work out I need to be able to use a non-USB dac, but utilize the USB port on my computer.
http://cgi.ebay.com/Native-24-96-USB-Spdif-I2S-Converter-Upgrade-Power-/270687116178?pt=LH_DefaultDomain_0&hash=item3f06359b92
http://www.6moons.com/audioreviews/trends4/usb.html
http://www.audiophileproducts.com/usb-to-spdif
Discussion, suggestions, thoughts, experience's would be appreciated.
Post edited by heiney9 on
  • drselect
    drselect Posts: 664
    edited January 2011
    H9, is the old/new computer a desktop or laptop? Could you pull the old soundcard out in put it in the new computer?
    edited January 2011
    drselect wrote: »
    Desktop and I've thought about that, but not sure it's compatible. Really like the idea of USB, but if the conversion to S/PDIF is poor w/ a reasonably priced converter then I'll abandon it. My office rig sounds so good I'm really not looking forward to upsetting that.
    The thing with buying a new soundcard is all the other crap it comes with, like 7.1 and all the DSP modes, etc, etc..........have absoultely no need for that stuff.
    The TeraLink X-2 looks promising and I can purchase an external linear power supply for it.
    http://www.teradak.com/ProductsView.Asp?id=21
  • coolsax
    coolsax Posts: 1,826
    edited January 2011
    I've heard good things about the ARCAM RDac if you want to stay with going USB,.. its an ASYNC USB dac and computer Audiophile had a pretty good review on it.. not sure if its a wall wart PS or not, which I know you're not a fan of.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
    edited January 2011
    coolsax wrote: »
    Cost?
    I have 2 dac's right now, not really looking for a 3rd unless it's <$300 and can best the (2) I already have. My other longer term option is to replace the Adcom GDA600 in the main rig and move it to the computer rig. But I just spent about $250 modding it and it really sounds fantastic. I'm afraid to better it I'd have to spend around $1K. Not going to do that.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2011
    Here is stereophile's review of various digital items. The first item appears to be what you want, but at $450 it is not geared towards the Emo crowd who expect greatness for nothing. :wink:
    http://www.stereophile.com/category/computer-audio-reviews
    http://www.stereophile.com/content/halide-design-spdif-bridge-usb-spdif-converter
    edited January 2011
    Thanks for the links..........I see a Stello in there too, forgot about that one.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    The Musiland 02 USB DAC that I have gets really good comments on headfi and other computer audio forums as a USB to S/PIDF converter and a lot of folks seem to use it to do that conversion ahead of another DAC.
    DKG999
  • coolsax
    edited January 2011
    the RDAC I think is around 425 I think, so its a little more than your $300 mark, but the reviewer seems to think its bests the Cambridge DacMagic fairly easily. I've thought about going that route, If I decide to go PC/laptop as my source, the Async USB will allow for Hirez tranfers up to 24/96, which most USB DACs don't currently do but i'm sure will become more commonplace.
    Main 2ch -
    TV 3.1 system -
    edited January 2011
    dkg999 wrote: »
    This one?
    http://cgi.ebay.com/USB-Digital-Sound-Card-Musiland-Monitor-02-US-/260545115814?pt=LH_DefaultDomain_0&hash=item3ca9b2f6a6
    Looks like I have about 5 solid choices all ranging from $35-319.
    I think rather than rush into it I will explore a few op-amps for my current USB dac. I think it has potential. Not looking for world class performance, but atleast as good as the AMC DAC8 or close.
    Keep the discussion going, but so far some great choices.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    Yes, that one. There's a thread over on headfi with lots of info.
    DKG999
  • TG Meat
    TG Meat Posts: 159
    edited January 2011
    Check out the Hiface, ordered one, but got a Logitech Touch instead.
    Anthem D2v
    NAD M50 Music Server
    B & K Reference 200.5
    Parasound A21
    B & W 804 (Mains)
    B & W HTM1 (Center)
    Polk Rti4 (Surrounds)
    PS3
    Seaton Submersive HP
    Pioneer PDP 6010FD Kuro
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    TG Meat wrote: »
    Wow! That's pretty crappy service when you don't get what you ordered :rolleyes:
    DKG999
  • zingo
    zingo Posts: 11,258
    edited January 2011
    I use the Musiland 01USD in my system and haven't considered upgrading it. It is USB powered and has a maximum rate of 24/192 unlike many devices which is why I picked it. Plus, I like it because it only does USB to S/PDIF conversion with digital coax/Toslink/BNC output; no analog output. I've done some A/B testing between it and the digital output on my MOBO, and it does sound better. I have not had the opportunity to test it verses the digital output on my Musiland sound card with used similar architecture, but the 01USD feeds my NFB-7 DAC a good signal on any of its outputs and I have no complaints. At $71.95 with free shipping on ebay, its a great deal and a nice digital transport.
  • Face
    Face Posts: 14,340
    edited January 2011
    edited January 2011
    Mike, I've been reading up on the HiFace and it seems to do a good job. $150 is really more than I want to spend as that's more than the DAC is worth on the used market.
    The other options are the Musiland 02 and the TeraLink X2. All roughly 1/2 the cost of the HiFace. Still have to do some research because some think the Teralink has horrible standard drivers. I'm fairly new to how the conversion from USB to S/PDIF works and what all the protocals are and what is available in Windows 7 for audio drivers and how they can be manipulated. I don't want to use Windows Kmixer type drivers, etc.
    It seems Kernal streaming, ASIO or Asyncrounus are all what I'm looking for, but not sure all these apply when doing the conversion from USB to S/PDIF, etc.
    edited January 2011
    My current dilema is I really like the way the AMC DAC8 sounds, but I have no way to get a digital signal to it from the new computer at this time. The Pop Pulse, which is USB capable, doesn't sound as good (to my ears) as the AMC DAC8 but it has the ultra convenience of being hooked up via USB.
    So do I spend $75-150 to allow me too hook up the AMC DAC8 via S/PDIF with a converter or do I look around for another USB DAC and hope it sounds as good as the AMC DAC8? Current used value of the AMC is about $100. I was thinking of upgrading to a used Monarchy 18B so I'd have the same issue of having to convert USB to S/PDIF.
    Then that begs the question if the conversion is poor then I'm not getting the full potential of the DAC and on top of that this is a secondary rig so I like to keep costs down while still have very good sound.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2011
    Brock - can't get to the website from work, but doesn't Parts Connection offer a USB to S/PDIF converter module you can install in the AMC DAC? It seems like it was a Burson unit IIRC.
    DKG999
  • Face
    Face Posts: 14,340
    edited January 2011
    Speaking of Burson, this would fix all your problems. :)http://bursonaudio.com/HA_160D.html
    edited January 2011
    Face wrote: »
    Very sweet looking piece of gear, but no tubes and a bit more than I want to spend :smile:
  • 98Badger
    98Badger Posts: 317
    edited January 2011
    heiney9 wrote: »
    I know you already said the Hiface is more than you want to spend, but it will do all three of the things listed above. I used one for a while with a Cambridge Dacmagic (kernel streaming) and it was definately an improvement over the Cambridge USB.
    edited January 2011
    98Badger wrote: »
    Good to know............I am leaning that direction based on what I've read. I'm going to see if I can get my current USB dac to sound a little better. It's pretty bass shy right now compared to the AMC. Hopefully rolling an op-amp or two will change the sound more to my liking.
  • Bobsama
    Bobsama Posts: 526
    edited January 2011
    Any number of solutions to your problem are available.
    #1 way would be to buy an expansion-card sound card with digital-out. (PCI-E x1 most likely; Asus Xonar DX is an option. For old PCI, there's quite a few more choices too.)
    #2 way would be to buy a USB-to-S/PDIF adapter (or, rather, a USB sound card with digital-out).
    #3 way would be a USB DAC.
    Regardless of your method, make sure you're bypassing Windows' drivers & especially KSound/KMixer. I'd recommend you use ASIO4All drivers. The drivers can be a PITA to get working but I managed to do it.
    On a side-note, sometimes, Toslink is available via the 3.5mm port. You can then get a Toslink-to-mini-Toslink adapter.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • strider
    strider Posts: 2,568
    edited January 2011
    I've been eyeing the HiFace for a bit now, but haven't bought one. I like the fact that there is a solid base of successful mods done to them. Here's 38 pages of posts to make your head go numb. The Musiland looks attractive as well, I really like having the BNC connector as an output option.
    Currently using Hagerman's converter, but it's limited to 44.1k. If your DAC can handle higher sampling rates, don't let your converter be the limiting factor in the equation. Hi res files sound way too good to not be able to hear them.
    Wristwatch--->Crisco
  • ken brydson
    ken brydson Posts: 9,024
    edited January 2011
    heiney9 wrote: »
    This one?
    I have one of those that I won in a drawing at last years Seattle GTG that I've never used. I'd be happy to let you try it out if you want.
    edited January 2011
    strider wrote: »
    Thanks Ben, I'll read it.
    So far I've read this which is 40pp
    http://www.head-fi.org/forum/thread/468872/teradak-teralink-x2-released-19-1-10
    Right now it's between the above Teralink V2 with seperate power supply
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270687116178&ssPageName=STRK:MEWAX:IT
    or the HiFace
    edited January 2011
    That would be awesome, because I'm not sure how the USB conversion will sound.
    PM with details and we can work something out. I'll certainly pay shipping both ways.
  • ken brydson
    edited January 2011
    heiney9 wrote: »
    Just PM me your info and I'll ship it right out :wink:
  • strider
    edited January 2011
    One of the mods that interested me WRT the HiFace was seperating the power supplies for the various stages in it. Not relying on the USB connection to power the HiFace makes sense to me in terms of a sonic upgrade. Downside is that it looks like a real PITA to do without damaging the unit.
    The external power supply of the Teralink is a nice feature, IMO. Definitely would be a plus one in it's favor, for me, compared to the HiFace. It's got a BNC, too.
    Damn, that thing outputs I2S as well. Nice.
  • strider
    edited January 2011
    Gigaworks, an Ebay seller, has the Teralink for less and with free shipping. They're in Hong Kong, but the stuff I've bought from them has always arrived in a reasonable amount of time and in good condition.
    http://cgi.ebay.com/Upgrade-Power-Native-24-96-USB-Spdif-I2S-Converter-/120658624355?pt=LH_DefaultDomain_0&hash=item1c17d07f63
  • praedet
    praedet Posts: 314
    edited January 2011
    For a REALLY cheap solution, you can use this...
    I have played with one and it is better than the digital out on the same computer...
    But, I am getting a HiFace modified by John Kenny soon enough...
    HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
    Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
    2 APC H-15s and a Panamax 5400 for good measure ;)
    Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
