record smell how to get it out?
erniejade
I was at goodwill found Wings over America 3 lp set in great shape. When i got it home it smells like mold. the lp does not look moldy, no mold on the cover but it stinks!! how the heck do I get rid of the smell?
Post edited by erniejade on
You can try an ozonator...Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Ionizer, same thing. That will kill the stinch producing mold. Even if you can't see it, it might still be there. Febreeze kills germs and mold to.Most people just listen to music and watch movies. I EXPERIENCE them.
I didnt know fabreze helps kill mold. I will wash the record really good and fabreeze the cover in innersleves.
thanks!!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
I have an awesome ozonator box ... makes the cat box smell like its not there at all.Main Surround -
I had to look up what that was LOL ok that will help the room but will it get the mold out of the record jacket?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
WOOO they are like 400$Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
It's harder to do here in the winter, but I have had good luck misting the jacket and liner with a 3% hydrogen peroxide spray and drying outdoors on a bright sunny day. I've sprayed the jacket inside and out and gently propped it open with (believe it or not) a golf ball.
Vinyl probably shouldn't ever be exposed to direct sunlight and can be dried with a soft lint free cloth. I do not know if peroxide is harmful to vinyl, but it has worked for me on 2 use LP's I purchased on eBay that were once very mildewy, but now smell (and sound) great.
I'm guessing the hydrogen peroxide could fade the paper and cardboard too if overused, but it didn't seem to affect mine with the fine mister I used.
My chemistry is a bit rusty, but I think ozone and hydrogen peroxide might work in a similar manner.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Ooh, ooh that smell
Can't you smell that smell?
Ooh, ooh that smell
The smell of death surrounds you.
Sorry:biggrin::biggrin:2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Ooh, ooh that smell
Ooh, ooh that smell
Now thats funny Skynyrd!!!
Man i forgot how good the LP of wings over america was just looked up on amazon for a cd copy and the damm cd is out of print!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
inspiredsports, that would probably work the best. I will have to wait for a bit warmer day and put it in he garage for now. I still coulndt wait to hear it so i threw the lp in the old spin clean lol. i will do that for the cover though as soon as weather permits.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Put them out in the sunshine!!!! For real...
It will kill the smell.Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
I had a box of smelly records which lost their smell when I moved to a dry climate. Prior to moving they stunk up my basement. I'm thinking you could microwave them but have not tried it.Vinyl, the final frontier...
^ Never thought of that, but it could work. Especially would consider it for the jackets...
No, it's not (at least not at concentations you get at Wal-Mart) and yes they are...inspiredsports wrote: »I do not know if peroxide is harmful to vinyl...
Ozone = O3 Peroxide = H2O2
Both are not fully stable. Each disinfects through the release of its extra Oxygen atom...More later,
Tour...
Vox Copuli
Wood glue will likely take the smell out of the vinyl itself; perhaps an open box of Baking Soda with the LP cover both in a sealed box.Magnavox 185 modified amplifier
Vista Phono+
Technics SL-D2 with ADC XLM MKII improved/AT440OC
Polk Monitor 70 + CS2 -
Naptha, and a Bic lighter.
I keed, I keed......:biggrin: -
If it's the record itself that's smelly, vinyl-zyme should take care of it. Sleeves you can toss and replace with anti-static, plastic innersleeves. Misting the jackets or leaving them out in the sun should do the trick for the covers. Afterwards, store them in plastic outersleeves.
http://www.squaredealonline.com/browse.asp?v=63
That is what I was thinking
Ben
