3 subwoofes to mono amp
help me
hello i have a 12" rw soundstream it is a 4 ohm and 2 other subs both 4 ohm 800 watts max they are theXR-2512 12" 800 Watt Xplore Series Woofer . the only thing is i have a PLANET AUDIO AC2600.2 2600W 2 Channel amp. how could i hook up all three? please help please explaine in detail how it would work or why not:)) thanks for the help
Post edited by help me on
btw idk if it is mono but the planet audio is what i got
I love this screen name
haha thanks its true
Im not into car audio but basic electronics is, if they are 4ohm subs wire them parallel only if your amp is 1ohm stable. Also, can your amp be bridged to one channel?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
The first sub from the spec is dual 4 ohm VC. Wire that sub in series (8 ohm) and then wire everything together parallel for a ~ 5 ohm load.
Or wire 3 VC in parallel for ~ 1 ohm load if the amp is rated for such. You would leave one of the VC's on the first sub disconnected. -
Don't hook up all three. It will sound terrible. IF you're hooking up 3 subs, use 3 of the same sub.
If those 3 are all you have, just hook up the two that match. It will sound better, trust me.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
here are the specifications on the amp
RMS Power Range : 1800 Watts
Number Of Channels: 2
Maximum Power: 2600 Watts
Frequency response: 20-2000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
Handling Power:
900W x 2 @ 2 Ohms
1800W x 1 [Bridged] @ 4 Ohms
Bridgeable Trimode Operation
Input Sensitivity Selector
Variable Bass Boost (0 to +18dB)
Continously Variable High Pass and Low Pass Crossovers
Low and High Level Inputs
Power and Protection LEDs
Heavy Duty Set-Screw Style Terminals
Crome-Plated Connections
Illuminated Logo
Remote Subwoofer Level Control
Authorized Internet Dealer -
Features
Handling Power:
900W x 2 @ 2 Ohms
Illuminated Logo
If you really want to hook up dissimilar subs then mono the Amp and run the VC's wired as mentioned and you will be ~5 ohms. Perfect for the Bridged operation.
