Laptop > Dac >pre/amp > speaker buzzing (help!)
dhart86
My speakers are humming /buzzing pretty loud
Please tell me if I did something wrong. When my source is the CD player there is no problem.
Problem is from the following set-up:
Dell Laptop (usb) > musical fidel.V-Dac > rotel pre > yaqin tube buffer> adcom amp > Lsi 7's
The problem could be usb cable or soundcard? please help
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Second Rig:
Post edited by dhart86 on
Is the laptop plugged into its AC adapter? Take an extra stock power cord and rip out the ground prong, or use a cheater plug and see what happens.For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
thanks doc, I will give that a tryMain Rig:
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Since it is a laptop, unplug it (as a test).
if the USB is truly galvanically isolated from your PC, there could be no place for some DC to ground to. Thus, ground loop.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I have that same problem. When I disconnect the AC Adapter and go battery only, it gets better, but I also have a second monitor plugged into 110 and that has to be unplugged too for it to go completely quiet. I'm going to go try the 3 prong to 2 prong grounding adapters right now.
Wow, I just noticed . . . my 3,000th post!VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
i have a bunch of "higher" end dc-dc converters (i.e. PicoPsu) they ALL sound better with the ground floated, noise just dissapears, even real low db grunge.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
inspiredsports wrote: »I have that same problem. When I disconnect the AC Adapter and go battery only, it gets better, but I also have a second monitor plugged into 110 and that has to be unplugged too for it to go completely quiet. I'm going to go try the 3 prong to 2 prong grounding adapters right now.
3K! Let us know how it works out ...For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I just tested with gray 3-prong to 2-prong grounding adapters in place (on Dell AC Power Adapter and extra monitor) and it immediately and completely cleaned up the noise I was experiencing.
I'd been unplugging and running from battery only, so this tip was much appreciated!
I hope it solves dhart86's (OP) problem also.
P.S.: Obviously, clipping the ground prong as someone suggested above would also work, but the grounding adapters preserve the protection that prong offers when not listening to music through the DAC.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
Problem solved! Wow, the Cheater plug did it!
Thanks Doc! Yur da bestMain Rig:
Second Rig:
