jinjuku....part deaux
^ and refreshingly delicious.
I see in Jinjuku's sig he has a pair of Zaph ZDT3.5's.http://www.zaphaudio.com/ZDT3.5.html Zaph's designs are very well regarded in the DIY community and if Jin built them as per Zaphs guidelines then he should have himself a good sounding high value speaker.I personally have built one of his small monitor designs and believe he developed IMO a great little speaker. http://www.zaphaudio.com/ZA5/
The ZA5 center channel actually outperforms the ZDT3.5 in refinement and dialog (IMO). Just seemed a bit more revealing.
I had them side by side (actually stacked top and bottom:biggrin:). Zaph has designed one hell of a woofer. The ZDT3.5's have more punch and bottom end however. -
Do people not like DIY around here?design is where science and art break even.
Ridiculously good for the price.Zaph has designed one hell of a woofer.
There are a few of us that are heavily into DIY.Do people not like DIY around here? -
Whadda mean was? Is.....is perfect. :biggrin:Political Correctness'.........defined
President of Club Polk -
SCompRacer wrote:Somewhere you gotta fit in and his hair was perfect.
Thus the werewolf reference...
"Just because youre offended doesnt mean youre right." - Ricky Gervais
