jinjuku....part deaux
    nooshinjohn Posts: 25,999
    edited January 2011
    ^ and refreshingly delicious.:tongue:
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    I see in Jinjuku's sig he has a pair of Zaph ZDT3.5's.http://www.zaphaudio.com/ZDT3.5.html Zaph's designs are very well regarded in the DIY community and if Jin built them as per Zaphs guidelines then he should have himself a good sounding high value speaker.I personally have built one of his small monitor designs and believe he developed IMO a great little speaker. http://www.zaphaudio.com/ZA5/
  • jinjuku
    jinjuku Posts: 1,523
    edited January 2011
    FTGV wrote: »
    The ZA5 center channel actually outperforms the ZDT3.5 in refinement and dialog (IMO). Just seemed a bit more revealing.
    I had them side by side (actually stacked top and bottom:biggrin:). Zaph has designed one hell of a woofer. The ZDT3.5's have more punch and bottom end however.
  • newrival
    newrival Posts: 2,016
    edited January 2011
    Do people not like DIY around here?
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    jinjuku wrote: »
    Ridiculously good for the price.
    newrival wrote: »
    There are a few of us that are heavily into DIY.
    SCompRacer Posts: 9,121
    edited January 2011
    shack wrote: »
    Yes, he's bad, he's nationwide.
    Somewhere you gotta fit in and his hair was perfect.
    F1nut Posts: 52,000
    edited January 2011
    Whadda mean was? Is.....is perfect. :biggrin:
  • shack
    shack Posts: 11,154
    edited January 2011
    Thus the werewolf reference...:wink:
