SDA delay?
backinthelou
backinthelou Posts: 36
edited January 2011 in Vintage Speakers
hi folks, I've used my SDA 2A's while watching movies, but I get a big lag between peoples' mouths moving and the audio. This also happens if I just do it during tv viewing. Is this normal? Should I forget using my SDA's for HT? I have tried different vintage recievers and it's always the same result. The sound magnificent, but delayed.
Post edited by backinthelou on
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited January 2011
    Are you using RCA outs ?
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2011
    The speakers have nothing to do with the sound delay. Check your TV or receiver manual for sync adjustment.
  • Vette C6.r
    edited January 2011
    Use the digital output
  • backinthelou
    edited January 2011
    I will try all options, after the Rams and Seahawks game. Thanks for the quick replies.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    Amen.
  • backinthelou
    edited January 2011
    It does this from the BluRay player and digital cable box-both from RCA's.
  • dorokusai
    edited January 2011
    Your television should have a sync option or adjustment for this very problem, depending on how new it is I guess.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2011
    Yep, your problem is electronic, and not in any way, shape, or form involved with the fact that SDA's are being used.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • backinthelou
    edited January 2011
    dorokusai wrote: »
    I am not taking the output from the tv, but I will give it a shot-after the game..:biggrin:
    And it's a new Samsung 55" LCD.
  • dorokusai
    edited January 2011
    Oh sorry, must've misread. Either way, it's not the loudspeaker, good luck.
  • backinthelou
    edited January 2011
    BTW, whatever the problem, I will not be parting with these. I just wondered if the SDA effect had something to do with my laggine issues.
  • OldmanSRS
    OldmanSRS Posts: 419
    edited January 2011
    No. The analog and digital sound outputs usually have some delay relative to each other.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited January 2011
    DUDE! the Mighty Rams lost! :eek:
    Just noticed where you are from... Hello neighbor.
    Regards,
    Matt :biggrin:
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
    heiney9 Posts: 25,429
    edited January 2011
    Very weird, but I'd bet the farm it's not the SDA's if it only does it for video. I use my SDA's for all sorts of DVD's and TV shows. Not an issue.
  • newrival
    newrival Posts: 2,017
    edited January 2011
    This is a pretty common issue for people using analog cables into a receiver, although it happens with digital as well. It has to do with the time it takes to process the video. If your receiver or TV can't compensate for it, there are delay modules you can purchase that fix this. I saw a demo at a place called "the little guys" here in chicagoland. I had the issue with my Onkyo receiver, but not after I upgraded to the Pio Elite.
    Here's what an option to fix it (or similar products): http://www.felston.com/dd540/
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    I had this problem for a while with my satellite receiver. The problem was with with the provider (Bell Canada). I could compensate with a setting in my Yamaha receiver. Eventually Bell provided a software fix and I haven't had this issue in well over a year. See if your receiver has a sync option. If not, well....good luck.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited January 2011
    If viewing my LCD TV using the HDMI output from the Satellite receiver direct to the TV for video, and using digital audio out from the Sat. box to the Sunfire TG IV, there is a delay. If I use the composite video output from the Sat. box THROUGH the Sunfire to the TV, the delay goes away. It may be, as with my setup, if you are using one path for video, and another for audio, there is a delay. When I watch the TV and use the audio system for sound, I use the Sunfire for both audio and video. That way there is no delay.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • newrival
    edited January 2011
    Good point. I found the length of delay to be variable based on connection type.
