Monitor 5jr upgrade question
punk-roc
punk-roc Posts: 1,150
edited January 2011 in DIY, Mods & Tweaks
So, I'm taking a look at the Monitor 5jr xover's I have in order to practice my modding skills before taking on my SDA-2's and Monitor 5-A's...
These 5jr's i got from Doro didn't come on a pcb.. just hot glued into the center of large plastic circular piece that holds the fuse, speaker terminals, etc.
Now I don't know anything about capacitors, etc, but thought i would get it down with pictures and reading the board..
I know the 5jr's are simple, but is this the only piece i need to change out? I just don't know what I'm looking at in here, lol
Thanks guys, not enough threads with pictures for dummies like me...
Jason
2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod
Post edited by punk-roc on
  • Outfitter03
    Outfitter03 Posts: 563
    edited January 2011
    Since I am not living in Mamby, Pamby land today I will give this a shot.:wink:
    There are two components that you want to trade out in this upgrade. The tweeter resistor and tweeter cap. There are several schematics in the vintage section for Monitor 5jr, although none showed a fuse that you mentioned.
    To confirm what you need to order you will need to clear enough of the hot glue off of the resistor to read the value. This should be the white rectangular object under the cap. Per the print it should be a 1.3 ohm 5w resistor, but may be a 1.0 ohm resistor. If the printing is not legible you will need to measure it's value with an ohm meter. Once you know the value you can order two new ones. Most Polkies use the Mills resistors from Sonic Craft or Parts Express and many recommend going to 10W power rating for a couple bucks more.
    The other component to replace is the capacitor which should be 12uF. In the picture posted you can just make out the units uF. Hopefully in front of that is a 12.
    Under all the hot glue you should discover wires running your signal path like this: + terminal of binding post to a lead on the buried resistor > opposite lead on resistor to wire on bottom of capacitor > top lead of capacitor T connected to .19mh inductor and chassis wire running to tweeter. The last connections are visible in the picture.
    Since you are not working on a PCB with this crossover, when you order the components it would be a good idea to get a little extra chassis wire to make your connections because you are building a point to point crossover and may need a little more wire than is supplied on the end of the resistors or capacitors.
  • Systems
    Systems Posts: 14,872
    edited January 2011
    Denial is not just a river in Egypt!:biggrin:
    Testing
    Testing
    Testing
  • Systems
    edited January 2011
    pepster wrote: »
    You know being a smart a$$ is a skill like anything else!:biggrin:
    Thats some good advice Outfitter.:wink:
    There are TONS of info on this sight for those particular x-overs.
    Might want to drop Ben a pm to discuss your options.
    Testing
    Testing
    Testing
  • punk-roc
    edited January 2011
    thanks outfitter.. I thought I would need to dig that white resistor thing out of the glue..
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    What is the value on the Black cap?
    Ben
  • punk-roc
    edited January 2011
    ben62670 wrote: »
    12uF - 50VAC
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • ben62670
    edited January 2011
    What do the resistors say?
    Ben
  • punk-roc
    edited January 2011
    i haven't gotten the resistor excavated yet.. its face down in the glue and i can't see the value on it.
    I've been being super careful since I'm not real clear on how everything goes together, so i didn't want break a wire off when i didn't know where it went hahaha.
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • ben62670
    edited January 2011
    Just don't tear both apart. You'll be OK:smile: It looks like both are paralel so you can replace it with one resistor. Can you measure the resistance with a multi meter?
    Ben
  • punk-roc
    edited January 2011
    i don't have a multi meter yet unfortunately.. just a voltage meter.
    Thanks for helping Ben. I've been meaning to get a multi meter.. I don't have time today, but I was going to dig the rest of the resistor out of the glue tomorrow and get everything figured out
    So that white box is really two resistors, not just one?
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • ben62670
    edited January 2011
    It certainly looks like two resistors.
    Ben
  • punk-roc
    edited January 2011
    so, i got the resistors excavated.. it looks like they are in parallel, one is 2.5ohm 10% 5W and the other is 2.7ohm 10% 5W..
    here's a picture for clarity =)
    So, not being an electronics person.. what could i replace these with? could i just get one resistor? or i could just buy two of the same type i'm assuming..
    Thanks Ben, et al. =)
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    I have a pair of mint grills for those if you're interested....complete with Polk emblems.
  • punk-roc
    edited January 2011
    i actually got some really nice, mint grills with my monitor 5As.. thank you for the offer though Mark.
    Random side note, can i use these 5jr crossover's in those 5As? just trying to figure out if i can actually test my work at the end =) but this has been a good experience either way though
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • dorokusai
    edited January 2011
    Cool, just figured I'd ask as I just moved them today while looking for someone else. There's very little difference between the two models, so much so that you should look closely at the xover schematic.
  • punk-roc
    edited January 2011
    will do, thanks Mark.
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • Outfitter03
    edited January 2011
    punk-roc wrote: »
    Jason
    Easy calculation to do with one of many parallel resistor calculators:
    http://www.1728.com/resistrs.htm
    The calculated value is 1.298 ohms. The calculated tolerance given the resistors 10% tolerance is 1.17 to 1.43 ohms. The crossover schematic specifies a target of 1.3 ohms. You could use two MRA-5 or two MRA-12 with the same values as found in the crossover. You could also use a single 1.2 ohm MRA-12 if accuracy is not that important to you. This is outside of the 5% tolerance though, which is a good rule of thumb for deciding acceptable values.
    http://www.soniccraft.com/mills_resistors.htm
  • punk-roc
    edited January 2011
    Thanks Outfitter, I'll take a look.. I'd rather do it right than easy, just gotta figure out what right is =)
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
